sub cabinet for eminance 15" sub
Old 9th February 2015, 10:36 PM   #1
glprich is offline glprich  United States
Default sub cabinet for eminance 15" sub
I have a pair of 15" 8 ohm eminance subs that were manufactured for a oem customer by Eminance, Im have the following info on the speakers:
05-RE OHMS 6.94 13-FS HZ 44.57
06-LE MH 1.13 14-MMS GMS 49.34
07-QM 5.32 15-CMS mm/N .2584
08-QE .800 16-RMS NS/M 2.5976
09-QT .690 17-VAS LTRS 266.16
10-XMAX MM 2.80 18-SD SCM 856.34
11-BL TM 10.97 19-EBP 56.0
12-EFF % 2.85 20-SPL dB 96.6
can anyone calculate the proper cabinet size for these subs?? Thanks
Old 9th February 2015, 11:37 PM   #2
sabaspeed521 is offline sabaspeed521  United States
Just thought I'd put this out there, what kind of design are you looking for? this strongly impacts the size of the ideal box. Thanks Assuming Bass Reflex (ported) I'm not sure if I would try and use these below 50 Hz as 2.8 mm of XMAX isn't much.
Ballpark I'd say 4-5 cu. ft. sealed or 9ish ported to get something remotely flat, my intuition and preliminary analysis tells me it may be futile to build a sub out of those drivers so you may have better luck using it as a low driver in a PA speaker.
What I learned from a short sim: 50 watts at 50 Hz will exceed it's excursion, don't bother making a sub out of it unless you only want to use it for very low output applications.
Old 9th February 2015, 11:49 PM   #3
Thanks sabaspeed521, I really wasn't sure if they would make good subs or not, I got them from someone using them as bass amp speakers, I was hoping th use them on the low end of my pa setup... Eminance told me they would rate them at 150 Watts rms
Old 10th February 2015, 12:04 AM   #4
bitSmasher is offline bitSmasher  Australia
bitSmasher's Avatar
Wouldn't call it a sub, unless you want it to woof alot
Looks like they came from a bass guitar cabinent?
Old 10th February 2015, 12:16 AM   #5
really not sure bitSmaher, that's why I'm hoping someone here can help!! btw by pa, I mean band pa, not like a DJ pa
Old 10th February 2015, 09:40 AM   #6
freddi is offline freddi  United States
freddi's Avatar
sounds like a "Beta" or similar weight (~38-42oz) ferrite magnet motor , lowish moving mass - do they have a 2.5" diameter coil? (Beta15cx had a 2" coil and qts around 0.53) it would be a waste of wood and packing space imo to make a real big box. Some old PA stuff which was vented probably had 3 or more dB peaking due to small motors.
Old 10th February 2015, 09:54 AM   #7
pinkmouse is offline pinkmouse  Europe
pinkmouse's Avatar
From those specs, I suspect they were for a 15" and horn top box, so okay for small vocal/ band PA, but no use for a home sub.
Rick: Oh Cliff / Sometimes it must be difficult not to feel as if / You really are a cliff / when fascists keep trying to push you over it! / Are they the lemmings / Or are you, Cliff? / Or are you Cliff?
Old 11th February 2015, 04:05 AM   #8
GM is offline GM  United States
GM's Avatar
Well, you could put it in 600 L tuned to 24 Hz to get ~108 dB ~flat down to 30 Hz with 10 W or ~187.4 L tuned to Fs to get ~115 dB down to 40 Hz with 150 W, though severely under-damped as Freddy assumed.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 12th February 2015, 12:52 AM   #9
lol so good of everyone to reply, but rather than hear all about their down sides I just want to know the best cabinet recommendation ! for the best performance possible, some one said 4-5 ft3 i know if i go to big I can loose power handling capability
Old 12th February 2015, 03:20 AM   #10
bitSmasher's Avatar
Best to know, what do you want to use them for?
sub cabinet for eminance 15" subHide this!Advertise here!
Two 15" in one hornmidbass cabinet? sladdbarn Subwoofers 4 19th December 2014 10:25 PM
Best Cabinet forEminence Kilomax Pro-15A 15" firstchoicett Construction Tips 2 3rd February 2011 02:23 AM
Eminance 15 beta vs Dayton DC380-8 for OB? JonPike Multi-Way 47 12th March 2010 10:23 PM
15" pipe for a bass cabinet I_Forgot Subwoofers 1 9th May 2005 02:48 AM
15" speaker for a bass cabinet Zaireeka Instruments and Amps 0 29th August 2004 02:11 PM
