Building THAM15 in 3/4" Plywood - diyAudio
Old 2nd December 2014, 05:49 PM   #1
Default Building THAM15 in 3/4" Plywood
Hello everyone, I searched around to see if someone has built this cabs on a 3/4" plywood but with no luck I have found any. I am getting ready to built this cab for knowledge and testing (with Dayton Audio PA385S-8) but I am planing on using a 3/4" Plywood from my local Lowes store (just for testing and learning purpose, I don't want to invest on a $80 sheet right now and maybe screw something up) and wondering if the change in thickness of the panels and braces, have a major change in the cab performance? It's a .75" is about 1.05mm bigger than the suggested 18mm panel thickness.
NOTE: I was thinking of enlarging the sides (panel 6), the upper front (panel 9), the lower front (panel 10) and the top/bottom (panel 7), to compensate a bit.
Questions:
1st - Using a 3/4" Plywood from my local Lowes store and wondering if the change in thickness of the panels and braces, have a major change in the cab performance?
2nd - Should I just go with the original external measurements and don't worry about the internal volume?
3rd - Should I enlarge outer panels to compensate a bit and leave the internal panels and braces alone or should I do something to the inside panels as well?
4th - Is the Baltic Birch plywood actually 18mm or a bit smaller?
Panels to enlarge:
#6 - 646.10 x 552.10
#7 - 253 x 464
#9 - 295.05 x 464
#10 - 95.55 x 464
Thanks in advance for the help?
Last edited by Fresh101; 2nd December 2014 at 06:10 PM. Reason: added size to panels to enlarge
Old 3rd December 2014, 12:43 AM   #2
tb46 is offline tb46  United States
Hi Fresh101,
Is your plywood really 3/4"/.750"? It usually ends up being 23/32"/.719" nowadays. Looking at it from prior experience w/ Hornresp simulations of this enclosure:
To question 1: No.
To question 2: I would. The driver makes much more of a difference than this minor wall thickness change.
To question 3: See #2.
To question 4: Yes, 18mm or 0.709" (haven't measured any in a while).
Oliver
Old 3rd December 2014, 01:45 AM   #3
Originally Posted by tb46 View Post
Hi Fresh101,
Hello TB46 and thank you for your response. I just checked on Lowes site and the plywood I was planing on using it actual thickness is .71" = 18.034mm which is really close. Thanks
Old 3rd December 2014, 01:49 AM   #4
I am getting ready to buy some clamps to start building but I just thought on how people hold down the inside panels while the glue cure, if clamps don't reach pass 3.75" from the edge? Thanks
Old 3rd December 2014, 03:01 AM   #5
sine143 is offline sine143  United States
I use screws... sometimes Brad nails. Whatever suites you really.
Old 3rd December 2014, 03:26 AM   #6
wg_ski is online now wg_ski  United States
Weight it. Lay the opposite side panel across everything (don't glue), and stack a bunch of 45 pound barbell plates on it for 24 hours. Evenly, of course. When that cures, flip it over, glue the last panel, and weight the other side. Use a few brads or screws to keep the corners in alignment, if necessary. If it isn't CNC-cut, it will usually be a little "twisted". A 16th of an inch or so is no big deal.
Old 3rd December 2014, 04:25 AM   #7
Got it, thanks for the advice.
Old 3rd December 2014, 09:13 PM   #8
bitSmasher's Avatar
I'd suggest the accuracy of your cuts is going to be a bigger issue than the thickness of ply
Old 4th December 2014, 12:14 AM   #9
What do you mean by this, I am extremely a*al about preciseness on cuts. I like to double and triple check on markings and cutting and then recheck after cutting of the exact measurement, I always aim to cut slight bigger (1/16") and start shaving to the exact size . So I don't think the accuracy will be a problem.
Old 4th December 2014, 01:30 AM   #10
evanc is online now evanc  United States
Location: New Jersey. About 1 hour from NYC and 1 min. from the beach
I say "measure twice...cut three times"
Sorry I had to, Evan
http://www.evancotler.com
Building a pair of THAM15 subs chris661 Subwoofers 19 2nd January 2015 11:07 PM
THAM15 - a compact 15" tapped horn martinsson Subwoofers 349 25th October 2014 01:41 AM
Building Speakers Using Regular Plywood kvk Full Range 15 25th February 2008 11:58 PM
"Void free" or "no core gaps" plywood rick57 Multi-Way 6 14th March 2007 02:09 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright ©1999-2015 diyAudio
