info on Wharfedale 12" 3028? - diyAudio
Old 26th November 2014, 01:50 AM   #1
Default info on Wharfedale 12" 3028?
Hi Guys,
I've done some searching and can't find any info about this driver. I doubt it's of any real quality but I got it for free so thought I might be able to use it for a cheap sub project.
Wharfedale 12" Speaker 3028 4 Ohm | eBay
Any info appreciated
Old 26th November 2014, 02:38 AM   #2
Cheap sub plate amplifier and 2cuft tuned to 30Hz is
as good as guess as any for a hifi 12" sub with no info.
If that doesn't work out because its not up to much,
you want it tighter, convert it to sealed and stuffed,
that will work as well as its ever going to as sealed.
rgds, sreten.
There is nothing more practical than a really good theory - Ludwig Boltzmann
When your only tool is a hammer, every problem looks like a nail - Abraham Maslow
Old 26th November 2014, 03:17 AM   #3
Thanks sreten,
I have a cheap ported 8 inch sub I was thinking of the taking the amp out of it and using it for the 12".
I was thinking sealed too or maybe just a badly sealed (aperiodic) box might give me the best room to maneuver?
Old 26th November 2014, 03:37 AM   #4
Vented pole and fairly large spacing on the basket between where the spider should be mounted and the top plate suggest that this particular driver might be capable of some decent excursion. I suggest you try to measure its parameters before committing to a design. There are ways to do this manually, if you have access to some basic equipment. It might be worth the effort.
www.diysubwoofers.org
Old 26th November 2014, 04:04 AM   #5
Thanks Brian,
Great website!
Vented pole, interesting
Measuring parameters is not something I've done but it is something I am curious about as is measuring in room response, I think these are issues you tackle naturally as your diy hi fi journey grows. I'll look into it.
Old 10th January 2015, 11:02 AM   #6
Just in case some one else happens by this driver it looks like it's from a wharfedale spc-12. Not a bad subwoofer apparently
vintage 15" Wharfedale 12" Goodmans AndrewF Full Range 4 6th January 2015 10:05 PM
Voice coil replacement on vintage Wharfedale 12" flyingtele Multi-Way 15 30th November 2012 11:01 AM
Need info on Lambda Acoustics 12"sub leonardluck Subwoofers 4 2nd May 2010 05:24 PM
ESS AMT 1AM - original 12" woofer info FORNO Multi-Way 2 9th March 2010 10:33 PM
Vintage Wharfedale 12" styrofoam-cone woofer GordonW Swap Meet 1 25th August 2007 09:38 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
