8x Aura NS3-193-4a subwoofer (Worth my time?) - diyAudio
Old Yesterday, 03:20 PM   #1
Kelocyde's Avatar
Default 8x Aura NS3-193-4a subwoofer (Worth my time?)
I have (8) Aura NS3-193-4a's [planning on] being fed 75 watts RMS.
1.5 cu ft, (1) 3" port @ 2.4" long
52 hz tuning
F3 of 45 hz
F10 of 39hz
I have access to a CNC table;
Any suggestions otherwise?
Old Yesterday, 06:59 PM   #2
chris661's Avatar
You could get away with a tapped horn with very high compression ratio. Have a play with Hornresp and see what you get.
Chris
Old Yesterday, 08:41 PM   #3
Kelocyde's Avatar
I have no idea how to even use hornresp; completely over my head.
I've read Danly's white paper...meh.
I've played with hornresp, read a few tutorials, and I still don't understand.
I'll have to sit down keep reading some more I suppose.
Thanks for the reply.
Old Yesterday, 08:57 PM   #4
xrk971 is offline xrk971  United States
xrk971's Avatar
You want to stick 8 of these 3in drivers in series-parallel to make equivalent of a larger driver for a tapped horn? That is about same Sd as an 8in driver. Look for a HR script for the MCM 55-2421 8in sub driver and put 8 of these in as a starting point. Kind of a waste of money as these are circa $20 drivers and for $30 you can get the MCM which will probably work better.
Old Yesterday, 10:36 PM   #5
Kelocyde's Avatar
Well I already have these; which I paid $9 a piece for them. I don't have the MCM driver.
I think of it as informational. Also, I'm not totally SET on a tapped horn, that was just one guy's suggestion and I don't even know how to design it; doubt ill go that route.
I've seen TL plans online which I requested my CNC guy to cut for me, as well as the box I proposed so I can try both.
Old Today, 12:08 AM   #6
sine143 is offline sine143  United States
if you've got a little bit of space, this flh looks decent for extension down to 45hz at 250 liters.
it will only take 10 volts to exceed xmax of 4.5mm one way.
Aura's NS3-193-8A and NS3-194-8E, any experience? bogicp Multi-Way 13 3rd May 2014 07:11 PM
Aura NS3-193-8A1 TL? ramiro77 Full Range 19 20th February 2014 02:07 PM
Aura NS3-193-8A castlesteve Full Range 15 25th October 2011 04:04 PM
Aura NS3-193-8A fence posts. castlesteve Full Range 13 10th July 2007 08:35 PM
ZaphAudio Aura NS3-193 / Dayton ND20TB johnmark Multi-Way 2 24th February 2007 04:26 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
