Replacement woofer for JBL HT1S - diyAudio
Old 6th November 2014, 04:23 PM   #1
Default Replacement woofer for JBL HT1S
I have a JBL HT1S and the I blew off the woofer. Dont ask me how, I am not too sure. The amp was only 100W RMS. Maybe the frequency was too low (there was no low frequency cut off on the decoder).
I am thinking about buying a new sub, but I already have this huge box, so might as well reuse it.
The spec's from the HT1S owner's manual are as follows:
Low Frequency: 12" High Polymer Laminate
Response: 35 HZ to 80 HZ
Height: 21.5"
Width: 25.25"
Depth: 175/8"
I think this is around 140-150l.
The port seems to be 2.9'' wide.
The cabinet walls are pretty thick. I would say at least 1/2" thick.
There is a lot of foam inside.
My goal would be to find a driver with a smooth response down to 25 HZ if possible. If you could recommend something that would be awesome.
Thanks,
Serge
Old 8th November 2014, 02:56 AM   #2
Anyone, any advice?
Old 8th November 2014, 05:07 PM   #3
If you have the T/S parameters for the original driver, you could match an aftermarket driver pretty close.
Old 8th November 2014, 06:39 PM   #4
bjorno is offline bjorno  Sweden
Send a message via MSN to bjorno
Originally Posted by sergedc View Post
Anyone, any advice?
Hi Serge,
Her is a way to match a tuned(fb) BR Volume by using the Driver Qts,fs and Vas:
PS Always check the Port Volume Velocity, IMO:Rec: < ~15 m/Sec Peak or < 10 m/Sec RMS. The shown Sim. using a 4" Port will not handle an Input Power more than 20 W Rms if using the Lab 12 Driver.
b
Old 9th November 2014, 02:26 AM   #5
bjorno, Thanks! I am very keen in learning this.
In the analysis on the right of the page, when it is trying different Qts (0.36, 0.38, 0.4): why is it using fs = 25 instead of 22?
So say: if I use this driver for my box:
Qts = 0.421 => Vb = 150 => ffc = 21.8 & f3 = 22.9
Where does the port come into the calculation?
Is this not saying that I can use any driver, and that the bigger the box the better the result?
Old 9th November 2014, 08:28 AM   #6
Baldin is offline Baldin  Denmark
Baldin's Avatar
Send a message via MSN to Baldin
Have 2 JBL HT1S and because I wanted to use another box (under the sofa in my HT) I found the volume to be around 120 l and the tuning around 25 Hz. Use e.g. WINisd to find a match.
Dayton DC300-8 seems to fit the bill quite well .... think it is a fairly good replacement
Visit www.sensibleaudio.dk or read latest news on Baldin's Blog
Old 9th November 2014, 10:05 AM   #7
Excellent. Dayton DC300-8 seems like a great fit a great deal. Thanks!
Will just need to wait to go to US to pick it up..... Does not seem to be available in UK or Singapore.
Serge
Old 9th November 2014, 10:43 AM   #8
But is this woofer (DC300-8) for subwoofer? It seems to be for a normal speaker?
Old 10th November 2014, 09:23 PM   #9
Baldin's Avatar
only down side as I see is a limited Xmax (4,3 mm) ..... but not sure the original is much better ....
There are better options today; more Xmax, better power handling and low tuning in a much smaller box .... but the old box is old school, big box high sensitivity.
You might be abe to find a better alternative .... use WINisd, just as I did to try ir out ....
Old 11th November 2014, 12:33 PM   #10
I bought the Dayton DC300-8. For 41 USD incl. shipping, this is a great deal I feel.
Thanks!
jbl woofer tomvu6204 Swap Meet 0 31st March 2013 06:11 PM
Woofer replacement for Infinity Reference 2000.5 Woofer kchilaka Multi-Way 0 28th September 2010 06:11 AM
Replacement woofer for JBL LM38 Sam Pietro84 Multi-Way 1 2nd July 2010 05:55 PM
Replacement Amp for JBL PSWD112 drjake Subwoofers 4 15th December 2004 09:11 AM
JBL 5in woofer Praudio Swap Meet 0 8th May 2004 10:35 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
