Tapped Horn Sub Using Low VAS drivers - diyAudio
Old 4th November 2014, 06:32 PM   #1
Default Tapped Horn Sub Using Low VAS drivers
I have the chance to pick up some sub drivers from these listed in the attached spec sheet. I have been considering building some Tapped horns to cover upto 100Hz in my front horn based active system.
I have looked at the Lab12 TH in the past but had concluded it was too big for the space i have in my corners, so was wondering if using a 10" driver allow a cabinet that acceptable.
The horn can have a line upto 4 m long and a mouth of around 800cm2 max.
I have tried simulating with Hornresp without any success an expanding and contracting line, not being able to get a flat response that goes below 35 Hz. What am i doing wrong or is it that a driver with stiff suspension (low VAS) isn't suitable?
See attached one of my poor attempts.
I am also not sure if the spec sheet values are 100% accurate as when i determine values for mmd for example on different coil configurations i get opposing trends form the publised data.
Old 4th November 2014, 07:13 PM   #2
sine143 is offline sine143  United States
nothing attached.
Low vas is generally a positive thing.
post t/s specs of desired driver.
Old 4th November 2014, 07:21 PM   #3
this is a mispost see earlier post with attachments
how do i delete this mispost?
Tapped Horn Sub Using Low VAS drivers vinylnvalves Subwoofers 14 11th November 2014 11:04 PM
Tapped Horn Low Pass AVT IM Subwoofers 2 11th August 2014 09:27 AM
~50 lb tapped horn, woofer under $100, high efficiency, low power? turbodawg Subwoofers 43 3rd December 2012 09:22 PM
Opinions needed on Tapped Horn drivers zobsky Subwoofers 11 2nd August 2010 03:36 AM
tapped horn isobaric drivers bubblersound Subwoofers 4 18th June 2009 03:42 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
