a little help, subwoofer build
Old 31st October 2014, 05:12 PM   #1
UCrazyKid is offline UCrazyKid  United States
Default a little help, subwoofer build
Hi guys!
So I have a JL Audio 10w3v2 in a 1 cu/ft sealed box wired for 4 ohms. I'm running 300 watts to it from an outboard mono block amp and bass management coming run from my Pre/Pro.
This box really did well in my car, but now it's in the house. I'm contemplating modifying the box. Thoughts?
1. build new 2 cu/ft box to retune
2. place a port in the 1 cu/ft box (will stay small then)
Any tips?
Thanks!
Andy
Old 1st November 2014, 02:52 AM   #2
GM is offline GM  United States
GM's Avatar
Greets!
Well, it depends on what your performance goals are, i.e. music genres, peak SPL, room layout vs speakers, sub, listening position, etc..
Personally, Id either build a ~3.2 ft^3/~20 Hz Fb extended bass alignment [EBS] alignment [white] using a pair of PRs or a bit larger inverse tapered TL [TQWT]/~20 Hz Fp, i.e. morph the cab and its necessarily large, long vent into one tapered tube [usually folded in half] and in either case, stick it up against a wall, or better yet, in a corner to ensure that it can handle the whole 300 W.
Sealed is ~3.2 ft^3/0.577 Qtc [yellow].
The TL would be a bit slower roll off variant of the EBS alignment, i.e. rounds over the EBS's more extended, but much sharper roll off, so tends to blend in better with a typical room's gain curve.
GM
File Type: gif JL Audio 10W3v2-D2 vented Vs sealed.gif (18.6 KB, 74 views)
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 1st November 2014, 12:47 PM   #3
bjorno is offline bjorno  Sweden
Send a message via MSN to bjorno
FYI:
b
Old 1st November 2014, 11:13 PM   #4
head_unit is offline head_unit  United States
I cannot imagine you could fit a port into the 1 ft3 box which would be big enough in diameter to flow enough air. I concur I'd look at a larger box. I prefer "under tuned" designs, with a bit of droop (yet more extension) at the low end.
a little help, subwoofer buildHide this!Advertise here!
Help me build first subwoofer injocus Subwoofers 10 28th May 2014 12:27 AM
Subwoofer build - Morel UW1258, 12" Ultimate Subwoofer mantha3 Subwoofers 46 10th October 2011 01:11 PM
need help with subwoofer build gtpower87 Car Audio 2 29th March 2011 04:14 PM
Help for my first ever subwoofer build crimar Subwoofers 4 10th May 2010 05:51 AM
how to build a subwoofer? nicovdk Subwoofers 7 26th December 2002 02:11 AM
