Mid-Bass horn - diyAudio
Old 24th October 2014, 09:54 PM   #1
koutrou is offline koutrou  Greece
Default Mid-Bass horn
Do you know any good midbass horn design for Beyma 15P80Fe ?
Old 31st October 2014, 07:25 PM   #2
Speakerholic
Cal Weldon's Avatar
Moved to the woofer section.
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
Old 1st November 2014, 01:29 AM   #3
djk is online now djk
djk's Avatar
Define the frequency range please.
Candidates for the Darwin Award should not read this author.
Old 1st November 2014, 12:33 PM   #4
I would a horn 100hz - 500hz and frequency range of Beyma 15P80Fe is 30hz - 5000khz....
Old 2nd November 2014, 05:43 PM   #5
bjorno is offline bjorno  Sweden
Send a message via MSN to bjorno
Originally Posted by koutrou View Post
Do you know any good midbas horn design for Beyma 15P80Fe ?
Hi koutrou,
DIY: Use this Sim. as a template for your design:
b
Old 2nd November 2014, 05:58 PM   #6
frugal-phile(tm)
planet10's Avatar
It should be noted that midbass is defined as 40-80 Hz. The OPs desired range us upperbass up well into the midrange,
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 2nd November 2014, 08:03 PM   #7
Originally Posted by bjorno View Post
Hi koutrou,
b
Thanks man too much!!!!
Old 3rd November 2014, 03:04 AM   #8
xrk971 is online now xrk971  United States
xrk971's Avatar
Look at Volvotreter's website. He has tons of plans, calculators, etc for mid and bass horns.
Download Section
Old 3rd November 2014, 05:24 PM   #9
dave
Dave,
It should be noted that "midbass", by definition, requires four ranges:
Bass (AKA Low), Midbass (AKA Low-mid), High-mid, High, each covering 2.5 octaves.
A single octave (as you suggested) is not an integer of the human 10 (+) octave hearing range when divided by four.
If we equally divide four ranges covering the 10(+) octave audible frequency range into the 32 ISO 1/3 octave points from 16 Hz to 20kHz, we can define the frequency ranges covered in each:
Bass is 16-80 Hz (8 ISO bands)
Midbass is 100-500 Hz (8 ISO bands)
High-mid is 630-3.15 kHz (8 ISO bands)
High is 4kHz to 20kHz kHz (8 ISO bands)
The OP's desired range of 100-500 Hz exactly fits the usual definition of "midbass", and since it would require a subwoofer below, does not by definition fit in the subwoofer forum.
The multiway forum currently has several midbass horn designs already under discussion that cover the range the OP is interested in.
Art
Old 3rd November 2014, 05:59 PM   #10
frugal-phile(tm)
planet10's Avatar
Art,
This is the set of conventions i have used for a long time:
20-40 low bass
40-80 midbass
80-160 upper bass
160-320 lower mids
320-640 mids
640-1.25k mids
1.25k-2.5k upper mids
2.5k-5k lower treble
5k-10k treble
10k-20k upper treble
dave
Mid-bass horn (easy to build) carpenter Multi-Way 196 18th March 2015 03:15 PM
Mid bass horn design Yasuo Kanda Multi-Way 18 5th May 2014 01:23 AM
crossing over TH to mid-bass horn Jimmy D. Subwoofers 1 27th December 2013 09:26 AM
Best mid-bass for 96cm horn? oldies Multi-Way 10 28th January 2013 03:08 AM
First pictures of my mid-bass horn, painted angeloitacare Multi-Way 16 20th June 2008 02:27 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
