hornresp driver database - diyAudio
Old Yesterday, 11:50 AM   #1
epa is offline epa  Netherlands
Default hornresp driver database
Since hornresp. 35,10 user have the ability to save driver parameters in a separate database.
David mc-bean made the db plain txt so they become interchangeable.
The database is to be found in the hornresponce folder.
So this topic is to swap databases between users.
Ill start with the eighteensound database.
some guidelines to make searching easyer(i'm open to sugestions)
example:
brand(space)size(space)type model(dash)ohm.txt
eighteensound 15 nlw 9401-4.txt
note : please double check the data before you start bilding/purchasing a box/driver!!!!!!!!!!!!!!!
tnx david mc-bean for this wonderfull program
one good thing about music ,when it hit you feel no pain.
so hit me with music
. hr driver db
Old Yesterday, 12:02 PM   #2
xrk971 is online now xrk971  United States
xrk971's Avatar
We should have an equivalent dB for drivers in AkAbak. That is always one if the things that helps to get going quick - not having to re-enter T/S params. I don't know why HR uses a format that requires additional steps to calculate Cms and Rms - why not just do it the way most manufacturers list it? e.g., Sd, Fs, Re, Le, Qms, Qes, (Qts), Bl, Mms, Vas, xmax.
AkAbak format looks like how it would appear as plain text (with units) when looking it up on website.
It can be one big file separated by a line for each driver.
Old Yesterday, 12:40 PM   #3
in hr you need to type 7 entry's in total.
it shure is a lot better then the way winisd does it .
you can always export the akabak script from hr.
then you also get the driver.
(thats how i do it to get me started in akabak)
. hr driver db
Old Yesterday, 01:10 PM   #4
xrk971's Avatar
I agree it is horrible how WinISD does it. Here is an example of how an entry look in Akabak. I like how comments can be added and the units are clear.
Code:
Def_Driver  '55-2421' | MCM 8 in, Qts 0.22, 8 mm xmax, 87dB
  SD=208.7cm2   |Piston
  fs=25.7Hz
  Mms=59.8g
  Qms=14.00
  Qes=0.22
  Re=3.4ohm
  Le=2.47mH
  Vas=30.4L
Old Yesterday, 03:59 PM   #5
A driver database is a good idea in theory but this is the problem:
If you need to double check the data you might as well enter the parameters yourself.
Also, unless you know how the parameters were measured they might not be useful. For example, are they manufacturer's published specs? From what year? (Specs sometimes change over the years.) Are they diy measurements? At what voltage? At what humidity, barometric pressure, and temperature? Is the driver broken in or not? Is the driver a good representation of it's model or is it statistically outside the average? (For example a batch with a stiffer suspension than normal.) Does the diy'er even know what he's doing when measuring?
And that's just a short list. For those reasons and others I am going to search for my parameters, since the source will usually give a good indication of their reliability. And I intend to maintain my own database of drivers in Hornresp. It's unlikely that I would ever use someone else's database. Like I said, it's a good idea but having to verify the data kind of negates the utility.
Adding to Driver Database, and Recommended Software lucadelcarlo Software Tools 3 15th April 2013 03:11 PM
Great driver database and search engine lowtherdream Multi-Way 1 4th August 2008 05:49 PM
WinISD driver database? NogginBoink Subwoofers 1 18th April 2006 04:37 AM
Dynaudio driver database David Gatti Multi-Way 3 31st January 2006 10:43 AM
Driver Database now online Rarkov Multi-Way 34 12th November 2003 12:04 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
