Need help Identifying this 18" RCF driver. - diyAudio
Old 14th August 2014, 09:29 PM   #1
Default Need help Identifying this 18" RCF driver.
Hello there.
Long story short. My father used to have a disco club (1997 - 2001.) we recently got all the equipment from the club back after it's been stored for over 10 years and not used.
Now all the equipment was produced by the italian company "peecker sound" 4x 900w (4ohm) amps. 4x500w (4ohm) amps. Running 4 18 inch peecker sound woofers and 4 mid-hii 12+horn peecker sound speakers. R
ecently i started restoring the equipment so i can start renting it.
It's all working very well. I spent about 30 hours cleaning the amps and we tested it all outside with a DJ:
https://fbcdn-sphotos-h-a.akamaihd.n...02610285_o.jpg
Now finally here is my question. The drivers in these speakers seem to be in perfect condition. And damn they sound good! But i just can't find any specifications (except the 8ohm impedance rating). And i'd really like the datasheet for these drivers. Now when i took them out i soon realised they look exactly the same like some RCF drivers.
There is a good chance that these are RCF drivers. On the back there is a "acoustic research labs" sticker. But that is just a section of peecker sound company so it doesn't tell me much. They however look exactly the same like some RCF speakers. On the 18 woofer there is an engraving:
L121000
i know some RCF speakers are marked with L12 right?
I wanted to send you some pictures of these drivers to ask you if you could please help ne indentify them. Guys from peecker sound don't reply the emails. If you recognise these 18 an 12 drivers please give me the models thank you very very much.
Here are the pics
Peecker Sound Oprema Photos by athlon-64 | Photobucket
So i seem to have found one of the drivers. The 12" inch in the mid-hii speaker seems to be an
RCF L12-544k
on the back of each one of my speakers there is a number engraved. On the 12' speaker it was L121001. When i first saw the L12-544k online i realised it looks the same. Then i saw the number and finally... that is the speaker.
Now i still haven found my 18's and i have another question. Are these genuine RCF drivers or are these copies from peecker sound? Either way they sound damn fantastic but considering the engraved number. The fact that drivers are absolutley identical and both produced in Italy. I think this is and RCF with a different sticker right ??
So here is my 12 driver:
http://i30.photobucket.com/albums/c3...ps390461a0.jpg
and here is a L12-544k that i found online:
http://mla-s2-p.mlstatic.com/9134-ML...5_112013-O.jpg
Parlantes Rcf L12-544k (De 310 Watts hasta 500 Watts) a ARS 3300 en PrecioLandia Argentina (81gozc)
Take a good look at the engraved number on this RCF that i linked and my driver and you'll see it's the same number. So is this a genuine RCF driver from 1997 ?
Also can you help me find these 18's i have :/
Old 14th August 2014, 10:27 PM   #2
Hate to say this but I would just measure the TS parameters with lab equipment and go from there, picture identifying subs is tricky because sometimes companies will buy slightly modified driver versions that have different power handling, XMAX, etc.
Old 14th August 2014, 10:43 PM   #3
So you think there is no other way? Because the mid driver (the 12" one) has the exact same number engraved as the L12-544K RCF that i found online. And they look identical.
Here is a video of my "18 running under about ~550w load. How does it seem to you. Do you think it can take more?
https://www.youtube.com/watch?v=VjWo...gf2wqiSXCv_4Fw
I recorded this at 60fps (720p) so you should see quiet well
Old 15th August 2014, 09:08 PM   #4
Since there was no smoke coming from the voice coil, it can definitely take more power .
Old 15th August 2014, 09:14 PM   #5
Well i taught the movement of the driver can tell me how much more can i take.
If i pushed this 18 woofer too far but didn't clip it what would happen. Voice coil meltdown or would the suspension fell apart?
Old 15th August 2014, 10:43 PM   #6
Most woofer failures are from burnt voice coils, though if driven hard enough below Fb (box tuning) excursion can sometimes rip the surround or spider, Xmech or Xlim damage.
If you know what the driver's Xmax is, you can see if that is being exceeded by eye. Excursion looked well under what I would expect Xmech to be in the video.
Old 15th August 2014, 11:28 PM   #7
So there is no way to find out the speakers RMS power by pushing it harder and harder... i might melt the voice coil.
Well then i don't know if there is any way to find out witch driver this is. If at least guys from RCF replied my email... L121000 should tell something.
One more question. The system that has been running in the club is:
4x 18" 8ohm woofers.
4x (12+horn)" 8 ohm mid-hii"s
Now those speakers have been running of: 4x500w @ 4ohm amps + 4x900w @4ohm amps.
That means that each mid-hi speaker has been getting about 300w at the amps maximum and each woofer about 550w.
However in case i only had 2x900w @4ohm amps + 2x500w @4ohm amps what i could do is connect 2 + 2 woofers in parralel at the big amp and get 4x450w from it because impedance would go down to 4ohm and then do the same with the mid-hii"s and get 4x250w from only one amp.
Now if i'm not crazy that means that 2 more expensive amps have been bought to get just about 800 more wats at the entire system??
I'm asking this because it seems to me that connecting 8x 8ohm speakers directly to 8 amp channels that are stable @ 4 ohms means using a lot less then their maximum potential? It's kind of non-efficient right? The only good thing is that amps are never going to overheat or be stressed too much right?
Old 16th August 2014, 06:58 PM   #8
Less power dissipation does create less heat, so yes, the amps will last longer driving a higher impedance.
Discos often have the amps quite some distance from the speakers, long speaker runs at 8 ohms have a much better damping factor than at 4 ohms.
While the power difference between 8-4 ohm operation is little more than a dB, a reduced damping factor can make a sonic difference in "punch" and detail, damping factors of less than 20 tend to make speakers sound more "flabby".
Art
Old 16th August 2014, 07:09 PM   #9
I understand . So my goal is not allways to torture the amp with the absolute max it can give me. So now i just need to realise witch drivers are my woofers running. To be honest i really don't know how am i going to do that. I hope RCF replies my email.
One more question. My 12"s are RCF L12-544K. Theirs RMS power rating is 300w and AES power rating is 400w. What do you think is the maximum power i can safely give them for playing music. Would they run fine under a 400-450w load?
You can find the specs here: http://static.elitesecurity.org/uplo...942696/rcf.pdf
And yes. I'm asking for the max power considering they are not running a full range signal. I set the crossover at 130hz so they don't play anything below.
Old 16th August 2014, 07:25 PM   #10
It really depends on the frequency content, HP at 130 I'd say you are very likely to be fine Primarily because mid range content isn't usually a constant sine wave like some low bass is and thus your average power dissipated across the Voice coils will be 1/3 or 1/4 what the "peak power" it will be seeing. Still, whenever you reach the maximum power a driver can handle you should be wary of distortion figures (use your ears to determine if it's too much)
15" RCF bass driver - cause of ticking sound? capslock PA Systems 26 17th May 2013 08:23 PM
Isobaric JBL/RCF 18's mclsound Subwoofers 9 30th September 2012 11:21 AM
Scaling up the SS15 for an 18" driver and other compact 18" designs col Subwoofers 32 23rd January 2012 10:17 PM
Huge 2-way with 18" woofer and 2" exit compression driver? BHTX Multi-Way 15 23rd June 2011 10:59 AM
RCF L/18 551 info timothyldodd Subwoofers 4 31st October 2008 01:58 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
