Eminence LAB15 Subwoofer, 4ohm, Special Run for CHEAP on ebay
@ David McBean
I'm sorry if you thought i underestimated you 😱 i Certainly do NOT ! I was only trying to convey how it is for some of us to try & get our heads around certain aspects of HR.
If you can think of a better way to present the Hornresp scaled schematic diagram, in particular for offset driver and tapped horn systems, then I would be very interested in your ideas.
If i do i will 😉
If we could view more than one window @ a time, i believe that would be a BIG help. We could then see the changes happening in both the schematic & for eg power response etc @ the same time 🙂 If it can't be done in the near future, how about having 2 versions of HR, for eg named slightly differently, so we could use both in tandem. Then we could load the same file in both & view the changes in different windows 🙂
If i do i will 😉
Thanks.
It's not going to happen. Note however that if you are using the Loudspeaker Wizard and, for example, have the Power chart displayed, you can instantly toggle back and forth between the Power chart and the Schematic by pressing the S key. This enables the effect of changes to be readily monitored on both windows. Note also that Ctrl+C can be used to capture a chart trace and Ctrl+V used to display or hide the captured trace. This comes in handy when wanting to see the effect of changes on a specific chart result. The captured result is the light-green trace in the attachment.
This can be done already. Take a copy of the Hornresp.exe file, rename it as Hornresp1.exe and place the Hornresp1.exe file in the same folder as the Hornresp.exe file. If Hornresp1.exe and Hornresp.exe are both run together they will share the same Hornresp.dat data file.
Making a change using one copy of the program will not automatically update the data seen by the other copy. Running two copies of Hornresp simultaneously in file-sharing mode is fraught with danger, and is not something that I would recommend.
@ David McBean
Hi, yes toggling with S is not 100% ideal, but definately useful, Thanx 🙂
I made a copy of the Hornresp.exe file, & renamed it as Hornresp1.exe and placed it in the same folder as the Hornresp.exe file. I ran Hornresp.exe & opened a sim, then tried to run Hornresp1.exe, but i got this error ?
It works for me 🙂.
As previously advised, it is not something that I would recommend doing, though.
