New sub design? Constricted Transflex, simple build (series tuned 6th order)
Old 13th July 2018, 06:21 AM   #2091
freddi is offline freddi  United States
freddi's Avatar
power handling with Kappa12a should not be an issue in home use. Do initial sims look strong enough for some pro use?
Old 21st July 2018, 09:52 AM   #2092
Matthew Morgan J is offline Matthew Morgan J  United States
Matthew Morgan J's Avatar
Smile Akabak Dabbling
Freddi ,
I would say so yes
that's quite a complex script - as its a bit larger than the "X15"
The K-slot required a great deal of code (the latter portion of the script) , the rest of cabinet didn't require much code ...
will some lowr qts 15 fit the same cabinet you're working on?
Freddi,
Yessir, i would just adjust the width so that a 15" driver will fit ...... If you would rather go with a 15" just let me know which model and i will plug it into the script
Old 22nd July 2018, 02:34 AM   #2093
freddi's Avatar
MMJ - which do you think would make the overall more interesting project 12" or 15" ? I don't think either my JBL M151 or 2035H are current drivers.
(btw - you're a mighty-mighty-man to work out that damned K-slot)
M151 , being a guitar speaker, is pretty lively - its either that or Kappa 12a (it might
be more interesting to see what can be extracted from Kappa12a)
Def_Driver "JBL M151" |15 inch woofer Xmax 5mm Qts 0.25
Sd=880cm2
Fs=45Hz
Mms=70g
Qms=2.8
Qes=0.27
Re=4.8
BL=18.8
Le=0.72mH
Vas=198.2L
Old 23rd July 2018, 01:06 AM   #2094
freddi's Avatar
It would be interesting if a 15 inch version can offer a good alternative to the original 15 inch Karlson enclosure (and GregB's "Karlsonator" spinoff. (-the original Karlson can outperform some horns imo - - Cogent's Steve Schell feels that way too)
Old 26th July 2018, 02:13 PM   #2095
brookhart995 is offline brookhart995  United States
brookhart995's Avatar
Default How much stuffing?
I am building 4 of the 15” version from post #932. I have summed the Dayton PN395-8 Neo drivers and the simulated response looks very good using the Hornresp inputs from that same post by TB46 (#932). I already have the drivers which also sim well in the THAM-15. I have two questions: 1. How much and where should I put stuffing inside the enclosure, 2. In the drawing, there is an angled piece near the mouth that is drawn with dotted lines. Is that piece required and/or how critical is it to the response?
Here is the driver, if your not familiar with it.
Dayton Audio PN395-8 15" NEO Series Pro Woofer with 4" Voice Coil 8 Ohm
Thanks all!
Old 26th July 2018, 02:45 PM   #2096
I think either one would be interesting and worthwhile
Hehehe, awwwe shucks I can't take the credit though because back in the days i believe i had guidance from XRK and it still took me some time to figure out how to script the slot ...It probably isn't exactly perfect but close enough i think ...
Sd=880cm2
Fs=45Hz
Mms=70g
Qms=2.8
Qes=0.27
Re=4.8
BL=18.8
Le=0.72mH
Vas=198.2L
Freddi, if you would like to go with this M151 it is no problem , i will plug in the parameters and adjust the cabinet's width ......If you would like to stick with the Kappa 12a that is fine too , just let me know ......
Old 26th July 2018, 04:46 PM   #2097
freddi's Avatar
lets go with the 12a as its in production. For a given cabinet volume, cutoff, a 12 has to do some work to equal the 15's displacement. Karlson "X15" was one cubic foot larger than his K12, similar Lf, but the 15's excursion was less.
Old 26th July 2018, 05:19 PM   #2098
freddi's Avatar
Brookhart995 - depending upon what low end you need - MMJ might suggest a higher tuned Karlflex
here's a fudged 115BK Karlson type vs TB46's Karlflex
Old 26th July 2018, 05:30 PM   #2099
That’s a good response, can you point me to a drawing of that box for a 15” driver?
Old 26th July 2018, 05:46 PM   #2100
freddi's Avatar
I don't know if 115BK would go as deep as that sim (?) - here it is with an EVM15L outdoors with mic laying on the ground
ah - here's a 2 pi sim of 115BK with PN395-8 vs EV15L - as these little K move towards free space, the cavity peak looks more pronounced - hopefully a 3rd chamber can help some cases. That fudge looks closer than some Akabak sim done on Karlson
115BK makes a good midbass horn substitute for some cases and sounds good with a slotted pipe Karlson tweeter.
PN395 sims very nice in Jim Bell's SS15 cabinet
115BK's internal width ~19" - external 20.5"
there was no damping material in that 115BK
New sub design? Constricted Transflex, simple build (series tuned 6th order)Hide this!Advertise here!
6th order PPSL enclosure design. lbstyling Subwoofers 19 28th August 2015 01:37 AM
6th order design check? carneoleon Subwoofers 28 29th November 2013 04:39 PM
6th order series tuned aznboi3644 Subwoofers 2 3rd September 2008 03:36 AM
6th order bandpass design - TheWacoKid Subwoofers 5 2nd August 2006 03:02 PM
6th order bandpass design? SubNut Subwoofers 3 22nd September 2001 08:48 PM
