Richard Allan CG15 bass driver- what to do? tapped horn? Decware Imperial SO? - diyAudio
Old 21st July 2014, 02:13 PM   #1
DeonC is offline DeonC  South Africa
DeonC's Avatar
Question Richard Allan CG15 bass driver- what to do? tapped horn? Decware Imperial SO?
Hi guys
I can get a Richard Allan CG15 bass driver, but I am not sure what application it will work in. Here are the parameters:
Fs: 22
Qms: 1.49
Qes: 0.16
Qts: 0.144
VAS: 9.2 cu.ft.
Cms (M/N): 3.48
Mms (gms): 126.5
Bl (Wb/M): 26.7
Would this work in a tapped horn or a Decware Imperial SO horn? It seems to have too low a Qts for reflex (Onken or Karlson maybe?). Any ideas?
Thanks,
Deon
I don't suffer from insanity. I enjoy every minute of it.
Have a look at my favorite thread: Interesting YouTube video clips
Old 21st July 2014, 05:57 PM   #2
DeonC's Avatar
Here are some pics of the actual unit (unfortunately only one is available as the other one has been stolen):
Old 21st July 2014, 06:45 PM   #3
horn loading
and watch the power handling - very carefully.
Is it 25W or 40W?
regards Andrew T.
Old 21st July 2014, 06:51 PM   #4
DeonC's Avatar
Originally Posted by AndrewT View Post
horn loading
Is it 25W or 40W?
I am not sure. I will have to find out. Will it work in a tapped horn? I have not been able to master HornResp yet, so if someone could model these for me it would be appreciated. I would favor extension over sheer SPL, if possible.
Thanks,
Deon
Old 21st July 2014, 07:33 PM   #5
xrk971 is offline xrk971  United States
xrk971's Avatar
Is your landlord going to say ixnay to a low freq tapped horn?
Old 21st July 2014, 09:10 PM   #6
DeonC's Avatar
Depends on the size. Two MOAKs would definitely been out of the question. One big TH might not be so bad. OTOH, if he doesn't like it, one TH is much easier to sell than a pair of giant MOAKs.
Old 21st July 2014, 11:20 PM   #7
GM is offline GM  United States
GM's Avatar
Well, when I use Prof. Leah's math, it dictates such a low 'M' factor that you might as well put in an unflared TL or tapped pipe variant tuned to ~15.55 Hz; otherwise a large BLH coupled to a matching impedance amp.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 22nd July 2014, 06:51 AM   #8
DeonC's Avatar
GM
Hi GM
By unflared TL, do you mean just a straight-sided pipe? A pipe tuned to ~ 15.5Hz is about 5.5m long. I can get MDF boards that are 2.75m tall (and 1.84m wide). I can use those as a basis and make the speaker 2.75m tall. But what size must the internal cross-section of the pipe be (W x D)? Here are two possible ideas for such a beast:
In the upper pictures the TL is folded to the side. The TL on the left is shown with the driver mounted at approximately the 1/3rd point of the line and the other with the driver at the end of the TL. Which would you suggest is best? The next pic shows the TL folded behind the driver, not next to it.
My last and I guess most burning question is, what kind of response could I get from such a monster?
Thanks,
Deon
Old 22nd July 2014, 02:15 PM   #9
bjorno is offline bjorno  Sweden
Send a message via MSN to bjorno
FYI:
b's
Old 22nd July 2014, 03:08 PM   #10
GM's Avatar
What is the measured distance across the center-line of the diaphragm between the middle peaked roll in the surround?
Also, need you to measure the driver's [Re] as me and bjorno are getting enough different complete specs from the same published ones to make me wonder if either are 'correct' enough and even then it wouldn't surprise me if the measured specs are so different as to render what we do mostly moot unless the cab is made obviously oversized to allow some tuning flexibility, so wondering what size constraints you have.
Really sucks having such a valuable driver stolen.
GM
richard allan bensaudio Full Range 0 14th September 2013 10:57 AM
Air leaks in tapped horn - ruin bass or kill driver? loudsubz Subwoofers 5 24th June 2013 07:56 PM
Richard Allan nelsondog Swap Meet 1 19th October 2010 03:19 AM
Anyone familiar with this Richard Allan driver? homemade Full Range 1 18th April 2010 07:54 PM
Which driver for Jensen Imperial bass cab? atilsley Subwoofers 20 28th March 2010 03:50 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
