Help fixing a sub, step 1, mounting holes
Old 20th July 2014, 10:41 PM   #1
gcb0 is offline gcb0  United States
Default Help fixing a sub, step 1, mounting holes
Hi everyone. i've been lurking for some time, but i'm finally starting to actually do something and i already need help.
I have a beautiful custom made sealed sub that died... it has a SA250 amp and a dead 10in titanic mk3
While researching on what to replace the dead driver with, i can find lots of info here about frequency, and what's good match for the enclosure etc... but i now realized I'm stuck with the basic.
Mounting holes.
from the pictures of the ones i'm thinking to buy, they all seem to have different holes than the one that is in the enclosure right now.
i mean, most have the same 8 mounting holes. but a few have 6. and some have 6 or 4 and a cut on the top and bottom.
then, even the ones that have the same 8 holes, the specs say different center of screw to center of screw diameter. e.g. mine was measured to exact 260mm. but my first replacement choice says that diameter is 268mm or 254mm. will that make a difference? i guess 5~10mm difference should be fine, or do I have to find a exact match? the enclusure has nice t-nuts that i doubt will move much...
thanks!
Help fixing a sub, step 1, mounting holesHide this!Advertise here!
Is it OK to drill mounting holes in transformer laminations? Derekva Tubes / Valves 7 17th April 2011 06:37 PM
DIYaudio F5 V2 mounting holes sts9fan Pass Labs 1 28th February 2011 11:04 PM
drilling transformer mounting holes-bit broke! ThSpeakerDude88 Everything Else 5 27th October 2007 03:36 AM
adding PCB mounting holes in Eagle rjm Parts 5 11th May 2005 04:38 PM
ProAc 2.5 driver mounting holes Saci Multi-Way 4 10th April 2003 03:39 PM
