DAS 18G, this driver any good?
Old 16th July 2014, 02:11 AM   #1
hjf is offline hjf  Argentina
Default DAS 18G, this driver any good?
Hi all. Many years ago i buil a sub with a 10" Selenium 10SW2 driver. It's OK-ish. But now i'm looking for an upgrade. I want to go with a 18" sub. Since I'm in Argentina, and shipping is very expensive, I have limited options. I found this driver:
http://www.dasaudio.com/wp-content/u.../te_18g_00.pdf
How do these specs look for a subwoofer? I want to be able to reach 20Hz (less if possible). The room I'm in has only 2.7x4.5M so a 18" sub is overkilll. But it's fun!
Fs: 32Hz
Qts: 0.296
Qes: 0.31
Qms: 0.649
Xmax: 6mm
Old 16th July 2014, 03:14 AM   #2
NEO Dan is offline NEO Dan  United States
NEO Dan's Avatar
I'm sure it's capable of more than your 10" Selenium, but it's no 20Hz beast with the limited displacement it has to offer.
Dan
Old 16th July 2014, 05:41 AM   #3
GM is offline GM  United States
GM's Avatar
Greets!
Vb = Vas tuned to 20 Hz is doable @ ~ - 8 dB/107 dB/100 W max plus whatever room gain gets you and attenuate however much of the ~ -8 dB suits you.
So, how will it fit in room? Tall corner loaded tower, horizontal equipment ‘shelf’, seating riser or …………?
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 17th July 2014, 12:19 PM   #4
Inductor is offline Inductor  Portugal
Inductor's Avatar
Default DAS 18G with LF extension
reflex: 180.0 L@28.0 Hz
approximately:
30Hz@F7
20Hz@F15
(sorry if too big for the size of your room)
DAS 18G, this driver any good?Hide this!Advertise here!
Das ist aber Schade... wrenchone Pass Labs 27 11th September 2016 07:25 PM
Alternative driver for "Das Viech" campo selice Full Range 4 7th March 2014 01:55 AM
Was ist das? pjp Tubes / Valves 13 29th September 2010 01:28 PM
WTB: 18g magnet wire, cheap, decent qty. pjanda1 Swap Meet 3 28th May 2010 05:53 AM
Nos Usb Das Banfi T. Digital Line Level 4 5th August 2009 04:05 AM
