MDF board - diyAudio
Old 7th July 2014, 11:34 PM   #1
Default MDF board
Im building a second 54l sealed subwoofer cabinet, the first one I built I found a great woodworking website on what side to paint and what side to glue. I have since lost the article, I was curious if anyone can remember what side to paint (the smooth side or rough side) or happen to remember the website?
Old 8th July 2014, 12:17 AM   #2
frugal-phile(tm)
planet10's Avatar
Nope. But i wouldn't use MDF to build a sub.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 8th July 2014, 12:26 AM   #3
chrisb is offline chrisb  Canada
MDF sheets vary quite a bit in quality, and most of the brands we see in the commercial trade are smooth enough on both faces for paint finish.
That said, I generally don't use it in any of my speaker builds - except for jigs or grille frames - but that's a whole ' nother can of worms we need not open
you don't really believe everything you think, do you?
community sites t-linespeakers.org, frugal-horn.com commercial site planet10-HiFi
Old 8th July 2014, 03:02 AM   #4
NEO Dan is offline NEO Dan  United States
NEO Dan's Avatar
OSB and Masonite have smooth and rough sides...
Dan
Old 8th July 2014, 03:15 PM   #5
I hand picked the best sheets but theres still kind of a fuzzy side and a smooth side, either way I will hit it with a sander before I paint it. I didnt if there was a preference?
Old 10th July 2014, 03:55 AM   #6
Inductor's Avatar
I'm not sure if that's what you are asking, but generally you want a fuzzy side to glue and smooth one to paint or varnish (this good also with MDF/HDF natural color).
Old 10th July 2014, 04:30 AM   #7
NEO Dan's Avatar
It's better to seal it before you sand so you are then just taking off the fuzz, then seal it again before you paint to avoid issues with humidity expansion. Best to seal it on the inside too.
Dan
Old 12th July 2014, 02:55 AM   #8
Brushed on sealer or sprayed?
Old 12th July 2014, 01:53 PM   #9
GM is online now GM  United States
GM's Avatar
+1, especially if you live in a humid area like I do. Also, seal all edges before gluing and use glue block construction on all exterior joints if you plan to spend mass quantities of time, effort, cost to get a fine/gloss finish.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 12th July 2014, 02:04 PM   #10
GM's Avatar
Depends on the coating manufacturer's recommendation. If it doesn't 'spell out' on the can the procedure for the specific material to be sealed, then contact them.
Second guessing a chemist is as much a 'fool's errand' as self diagnosing a major illness IMNSHO. Whatever you do, don't use shellac as a sealer as I've seen some recommend except as maybe a first pass to save $$$, it doesn't protect enough against moisture.
GM
Sure Electronics New Tripath Board 4*100W class-D Amplifier Board 7788q Class D 337 13th May 2014 07:50 PM
MDF and "particle board" jmar Multi-Way 19 20th October 2009 05:15 PM
My Cambridge 500SE, needs an output board (to replace internal DAC Board) slbender Digital Source 0 15th May 2008 01:36 AM
Replacing room walls with MDF or Particle Board? Hybrid fourdoor Everything Else 5 2nd April 2004 01:46 PM
MDF/Sand/MDF cabinet details Petter Multi-Way 25 16th April 2002 02:10 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
