JBL 2245 H - diyAudio
Old 5th July 2014, 04:54 PM   #1
Default JBL 2245 H
Hi I have a JBL 2245 H that I put into a 10 cubic foot box tuned to 30 cycles.I am using it with Klipsh LaScala bass bins for the lower octave. I want to know if this driver could work well in a folded horn enclosure? or is it the wrong woofer for that ? thank you ,Scott
Old 5th July 2014, 04:58 PM   #2
kevinkr's Avatar
Why not post the TS parameters and then any of the more knowledgeable members could quickly and easily answer your question without having to look up the information themselves.
"Extraordinary claims require extraordinary evidence." - Carl Sagan
Old 5th July 2014, 06:48 PM   #3
Not a good choice unless you are thinking about a folded horn that would make your 10 cubic foot box look like a breadbox by comparison. 10 cubes is at the small end of what you want for a driver with a VAS of 29 cubic feet (820 L).
Old 5th July 2014, 07:21 PM   #4
GM is online now GM  United States
GM's Avatar
Got that right, and considering the 2245's output capability, who needs horn loading with LaScalas? Might be nice to add a short horn to the cab to get a potentially better blend with them though.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 5th July 2014, 07:22 PM   #5
Hi ON the JBL 2245 H The TS Parameters are: fs 20 qts .27 qms 2.2 qes .27 vas 821.2 eff 2.1 pe 300 x max 9.65 re 5.8 le 1.4 sd 0.130 bl 21 mms 185 flux 1.22 Any idea if i could build a folded horn with this driver.I have the tools and experience to build it I just need a drawing. and as far as size i have enough room for a say 3'x2.5' x6' .I should be able to get some decent horn length with something of that size?Thanx Scott
Old 5th July 2014, 07:51 PM   #6
Scott,
Yes, it's possible to fold a very long horn in a cabinet with a gross volume of 43.5 cubic feet .
Art
Old 5th July 2014, 08:51 PM   #7
So how would i go about designing this. I have lots of 3/4" mdf and i can double and even triple the sheets to arrive at approx 1 1/2" or 2 1/4" thick walls and brace the heck out of it.My present enclosure sounds great with conventional speakers but seems a bit slow for the bass bin.Thank you for your experience and willingness to share same.Scott in beautiful Eugene ,Oregon
Old 5th July 2014, 09:23 PM   #8
The free software Hornresp can help you design enclosures that fit the speaker parameters:
Hornresp for Dum... hmm... Everyone - Home Theater Forum and Systems - HomeTheaterShack.com
Model your 10 cubic foot cabinet first so you can compare the response of the horn design to it, and see if it's worth the work for the output (and size) increase.
The path length will be longer than your top cabinet- if you don't delay the tops, the LF will lag at the crossover point, which will sound "slow".
As it stands, using a Klipsh LaScala with the 18" would require time alignment at the crossover (or overlap) region to sound "tight".
Old 5th July 2014, 10:11 PM   #9
Thank you so much weltersys I will look into this .Scott
Old 14th July 2014, 03:49 AM   #10
Hi Scott
You’ve not specified exactly what you plan to use this driver for so I’ll just tell you of my experience where I’ve used the 2245 woofer in a 12cf ported enclosure tuned to 20 Hz.
It’s probably the best sounding woofer I’ve ever had, except that I wanted it for a subwoofer for my HT and that’s where I encountered its major weakness, its Xmax limit of inch (9.5 cm). And when they say 9.5cm they mean 9.5cm not 9.6 because this speaker very easily bottoms out mechanically producing a very laud and frightening whapping sound, in fact in my enclosure this driver can only handle 18 watts at 10Hz.
In a horn enclosure you’ll have to use a low cut filter not to allow any signals below 25 Hz other than that it should sound great.
The other problem with this driver is that the foam tends to rot after a few years so you should expect to have to re-foam it every now and then.
PJC
Wanted: Dead JBL 2240, 2245 or E155 18" woofer frame GordonW Swap Meet 1 29th May 2013 01:07 AM
Marantz 2245 truevision Solid State 2 25th October 2011 03:36 PM
Asking for JBL 2245 cabinet drawing. ITcity Subwoofers 3 27th June 2009 06:50 PM
Jbl 2245 Vs 2247 ??? Zero Cool Multi-Way 6 21st July 2007 01:51 AM
JBL 2245 open baffle Andreas Multi-Way 12 18th January 2004 09:54 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
