Boston Acoustics RS8 subs need enclosure, help anyone?
Old 11th January 2004, 03:11 PM   #1
rchua77 is offline rchua77  Singapore
rchua77's Avatar
Default Boston Acoustics RS8 subs need enclosure, help anyone?
Hi all,
I found a pair of old Boston Acoustics Rally RS8 8inch subwoofers in my storeroom. I need help building an enclosure for them. They're both 4ohm each.
Could someone help design an enclosure and the crossovers for them?
Tech Specs
Fs = 34
Qes = 0.42
Qms = 2.55
Qts = 0.36
Vas = 41.0
Re = 3.64
Le = 0.0
Sd = 234
Xmax = 10.2
Pe = 250
Any help would be appreciated most gratefully!
Old 11th January 2004, 03:32 PM   #2
diyAudio Member RIP
Some bass alignments :
For both units you'll need around 2cuFt reflex.
Max you can sensibly use is 3cuFt.
The drivers are not particularly suited to sealed box loading,
but you would be OK with a seled box of ~ 1cuFt.
sreten.
Old 12th January 2004, 09:30 PM   #3
rchua77's Avatar
Hey, thanks for the guidelines. It gave me some ideas.
I tried out some figures for myself and came up with this gain plot. Comments and suggestions to make improvements?
By the way, wats tuning frequency and the vent mach (red/green colour) ?
Thanks!
Old 12th January 2004, 09:51 PM   #4
diyAudio Member RIP
50litres at 34Hz sounds reasonable for a box with both drivers.
Tuning frequency in the frequency of the port / vent.
Vent mach is the air speed in the vent. A port 2" diameter and 4"
long has the same frequency as a port 4" diameter and 16" long.
The bigger port has lower airspeed, winISD changes colour if
the port airspeed is too high.
Play around with the diameter of the port under vents.
sreten.
Old 13th January 2004, 12:36 PM   #5
rchua77's Avatar
Any suggestions for a passive crossover?
I would like to have the subwoofers have an impedance of 8ohms, since they're 4ohms each, a serial connection would seem much safer than a 2ohm load.
What values should I use for the inductor, capacitor and resistor? What kind of layout should I follow?
Thanks!
Old 13th January 2004, 06:43 PM   #6
diyAudio Member RIP
A passive croosover is extremely unlikely to work well.
You haven't even mentioned the main pair of speakers.
Get a plate subwoofer amplifier.
sreten.
Old 14th January 2004, 03:07 AM   #7
kelticwizard is offline kelticwizard  United States
Wizard of Kelts
diyAudio Moderator Emeritus
Graph might be a little more visible with light background.
"A friend will help you move. A really good friend will help you move a body."
-Anonymous
Old 15th January 2004, 06:28 PM   #8
rchua77's Avatar
Hi everyone again,
I think I've decided to run an active crossover system for the woofers in addition to my bookshelf AE Aegis ONE speakers since the AE has one pair of speaker terminals. Noticed they're alittle low on bass.
I'll bi-amp them with one amp driving the Aegis ONE and another amp driving the BA subs. Sort of like a mix and match 2 way system.
I'm not too sure which enclosure is more suitable for the BA subs, closed or vented. I seem to keep running into ridiculous vent lengths when toying around with the tuning frequency. Anyone know whats a good tuning frequency for the subs ?
Suggestions and recommendations would be appreciated.
Old 15th January 2004, 07:22 PM   #9
diyAudio Member RIP
Originally posted by rchua77
Hi everyone again,
II'm not too sure which enclosure is more suitable for the BA subs, closed or vented. I seem to keep running into ridiculous vent lengths when toying around with the tuning frequency. Anyone know whats a good tuning frequency for the subs ?
As I've already stated the BA drivers are not suited to sealed
subs. Tuning frequency in a 54 litre box for the pair is 27 Hz
to 38 Hz.
Lets say 30 Hz.
For a 54 litre box = a 8.2cm (~3") diameter and 26cm (~10")
length, or 6.8 (~2.5") diameter and 17 cm (~6.5") length.
I'd suggest 75mm and 213mm.
Note graphs are for a single unit.
sreten.
Boston Acoustics RS8 subs need enclosure, help anyone?Hide this!Advertise here!
Has anybody listened to the Boston Acoustics T830 speakers? Jim85IROC Multi-Way 31 6th September 2012 02:06 AM
Boston Acoustics A150 jamwvu Swap Meet 0 6th July 2007 02:09 PM
Boston Acoustics HD 10 70s music Multi-Way 3 13th June 2007 09:30 AM
Boston Acoustics G5 Sub+GTR PR kinser Subwoofers 0 7th April 2007 05:27 PM
Boston Acoustics VR-M60 - Port Problem infinitesymph Multi-Way 2 29th June 2006 12:51 AM
Copyright ©1999-2017 diyAudio
