Passive 40Hz HPF
Passive 40Hz HPF
Old 20th June 2014, 12:30 PM   #1
moldo2 is offline moldo2  Denmark
Default Passive 40Hz HPF
To protect the woofer in a horn I'm building I'd like to filter out the frequencies below 40Hz so the excursion doesn't kill the driver(Hornresp sim says excursion will be 7mm max, but the driver has 5mm xmax). As far as I understand a single bipolar cap in series with the woofer will act as a passive HPF, but I assume it has to handle a significant amount of power? My question is, how would you guys go about cutting the low frequencies and protecting the driver?
Old 20th June 2014, 12:34 PM   #2
Brian Steele is offline Brian Steele  Grenada
At 40 Hz? The only sensible option is active filtering.
www.diysubwoofers.org
Old 20th June 2014, 12:39 PM   #3
conanski is offline conanski  Canada
+1, a single cap won't provide any protection with only a 6db slope you need an 18db-24db filter and that will cost you big dollars, so the better solution is to buy a PA processor(LMS) since you will likely also need delay and EQ for these things anyway.
Old 20th June 2014, 12:50 PM   #4
jaclement is offline jaclement
I used to have a pair of 3-way Infinity speakers with a 12 inch woofer. They had excellent bass. At some time I measured the dc resistance and found they acted like an open circuit. I presume they had a bipolar series capacitor
Old 20th June 2014, 01:09 PM   #5
Sealed or vented speakers?
Old 20th June 2014, 01:15 PM   #6
Jonhny is offline Jonhny  Sweden
Is it a problem if you exceed xmax that Little with sine Waves?
Old 20th June 2014, 01:35 PM   #7
The Infinity speakers were acoustic suspension (sealed) .
Old 20th June 2014, 02:59 PM   #8
Using a very large capacitor in series with the woofer is a well-known but hardly-used way of extending the bass response of a sealed alignment. You end up with a lower F3, but a sharper rolloff below that point.
Old 21st June 2014, 12:42 PM   #9
I'd like to know that as well, but I assume it is?
Old 21st June 2014, 05:35 PM   #10
weltersys is offline weltersys  United States
weltersys's Avatar
The type of signal makes no difference as far as excursion, but sine waves have only a 3 dB crest factor, much more average power than typical music, and double the power of the AES test signal which has 6 dB crest factor. Sine wave testing needs to be done quickly if done at the AES rating, or the voice coil can be burnt up.
Hornresp does not consider that excursion is often limited by the suspension, and as Xmax is exceeded, the magnetic force becomes less, requiring more power to move the cone any further.
An example of measured vs. Hornresp simulated excursion below.
HP is certainly a good idea to keep from wasting power and tearing up drivers, but I probably would not worry about a predicted difference from 5 to 7mm.
At any rate, I'd measure the excursion to see what it actually is.
Art
Passive 40Hz HPFHide this!Advertise here!
lpf and hpf setting. olsound Analog Line Level 26 25th July 2012 04:13 PM
Simple passive HPF for 2 channel fronts qguy Multi-Way 5 19th September 2011 09:41 PM
OPA627 Active HPF D_GR8_1 Chip Amps 22 24th February 2010 12:37 PM
split hpf issues? jethdub Chip Amps 0 6th June 2008 01:22 AM
CAP for HPF ? foo Multi-Way 0 27th March 2005 04:25 PM
