Old 11th April 2014, 07:25 PM   #1
Default Smashed in Dust Caps
I am considering buying a pair of speakers but the 12" passive radiators have smashed in dust caps. I am aware of the needle trick to carefully pull them back out, but I was wondering if anybody has ever tried a shop vac? With my shop vac, I am slightly concerned that I could suck off the entire dust cap if I am not extremely careful.
-Stu
Old 11th April 2014, 07:37 PM   #2
Well you could try 'suck, pull to desired straightness, switch off vacuum, remove nozzle' if you are overly concerned
Old 12th April 2014, 12:34 AM   #3
You could run the vac with a lamp dimmer or a variac.Or cut a hole or slot in the tube you are going to put against the cap and control the suction with your hand.
Old 12th April 2014, 03:17 AM   #4
tomtt's Avatar
Location: kansas city mo, and on occasion, around the world ...
tape.
Old 12th April 2014, 05:35 PM   #5
Default Vaccum cleaner!
I use a vacuum cleaner with variable power (turned right down) and preferably the sliding opening in the hose wide open. I gently increase power until the cap pops out.
Ben
Old 12th April 2014, 05:57 PM   #6
infinia is offline infinia  United States
infinia's Avatar
post an image there are many types of dust caps /as there are methods
uncontrolled shop vacs would be my last resort
like four million tons of hydrogen exploding on the sun
like the whisper of the termites building castles in the dust
Old 14th April 2014, 09:32 AM   #7
You could add control by lengthening the hose with a piece of pipe with a slit in it, the more you slide the pipe over the hose, the more power as the slit becomes shorter...
Or simply drill or cut holes in the extension pie and cover these like you're playing a flute until the power is sufficient
Old 14th April 2014, 11:52 AM   #8
Max Headroom's Avatar
Location: West Australia, straight over the road from the beach, natural ambient sounds only.
Default Done It A Hundred times...
Disconnect the shopvac hose.
Start the shopvac.
Put suction end of hose over dome.
Carefully introduce hose to shopvac input so as to regulate vacuum/airflow.
Carefully vacuum 'massage' dome back into shape.
Dan.
Will cooling fan extend life of old caps & transformers? Or just make worse w dust? Barclay Tubes / Valves 12 13th May 2013 10:22 PM
FS: Capacitor Lots: Oil caps, HV Film Caps, Polystyrene Caps mattattnet Swap Meet 1 8th December 2012 08:20 PM
Fostex FE207E smashed whizzer OzMikeH Full Range 10 21st December 2008 02:43 AM
Smashed Thiel speakers peranders Multi-Way 1 25th August 2002 02:18 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
