12" TH for HT - Please Check my numbers!!! - diyAudio
Old 21st March 2014, 11:26 PM   #1
Default 12" TH for HT - Please Check my numbers!!!
I've never built a TH before but I came across the design about 6 months ago and thought I would give it a try. This will be for home theater use only so I'm not concerned with anything >80Hz. After some reading and thanks to the diyaudio forums I think I have a workable design in Hornresp. The driver is an Emenince Eminator 2512 12". I don't have one of these yet nor do I have the $$ to drop on several speakers and learn after testing that it's not suitable, so I used the published specs which are here:
Speaker Detail | Eminence Speaker
After some playing around I've got a response with what appears to be respectable low extension with good spl. I noticed that at the rated power I'll be dangerously close to the Xmax limit if not exceeding it. And this thing is looooong. L23 is 4 meters. But, if I can fold it once, I may be able to squeeze it between the floor joists in the basement a pipe the the good vibrations into the living room.
I've modeled about 6 drivers in hornresp and this is the first one that I was able to get something that looked decent. But before I start making saw dust (or fire wood) I would greatly appreciate ANY feed back or recommendations, and PLEASE double check my numbers. I've attached some screen shots too.
Thanks!!!
Tim
Old 21st March 2014, 11:31 PM   #2
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
maybe your woofer has too high Fs (44hz)
sometimes we know very little, and sometimes we know too much
Old 21st March 2014, 11:54 PM   #3
I may be able to deal with the length, but will it 'work'??
Old 22nd March 2014, 03:15 AM   #4
GM is offline GM  United States
GM's Avatar
Sure! You need to convert to Par segments, then in the LW change the two 'manual' to 'auto' to see a bit more accurate sim though. Delete the data in 'Apt1', 'Lpt' as these have no function.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 22nd March 2014, 03:33 AM   #5
djk is offline djk
djk's Avatar
6mm x-max for $95 is no deal.
Candidates for the Darwin Award should not read this author.
Old 22nd March 2014, 12:17 PM   #6
I thought a lower Fs was the ticket but when tried I could not get significant spl near 20Hz. I've made the changes suggested by GM and try some more.
Thanks!
Old 22nd March 2014, 12:21 PM   #7
Not locked in to Eminence - have suggestion for others?? my kids always say I'm cheap. I prefer frugal...
Old 22nd March 2014, 02:57 PM   #8
GM's Avatar
……or best ‘bang’/‘buck’.
I don’t keep up with pricing, though IIRC, ‘Pat Bateman’ posted a best ‘bang’/‘buck’ [sub]woofer thread on this forum and there’s probably similar ones on HT forums around the net.
Regardless, now that you’ve opened this thread up, need to know more about the intended app and desired performance requirements and since it’s for HT, ~20 Hz is the normal lower limit for an 80 Hz XO point with a TH, so plan to use some form of EQ to protect it down low since movies today can have significant output down in the infrabass.
Any dimensional limitations?
Location in room?
Listening distance from this location to the mean seating position?
How loud on average, i.e. what is the audio system balanced/set to?
Intended max power available?
GM
Old 23rd March 2014, 01:20 AM   #9
Originally Posted by GM View Post
....so plan to use some form of EQ to protect it down low since movies today can have significant output down in the infrabass.
Location in room?
GM
I have a 2 way line level XO thats 18db in the low pass and also a 24db high pass thats currently programmed at 15hz but I can change that to 20hz to protect the driver.
As far as dimensions, yes and no. If I install it under the floor I have (external) 20" x 14-1/2" x ~96". My sub now are two Audiobahn 10" in a vented enclousre with a Dayton 250wt plate amp (see pic). The 10's were left over from a system I pulled from a truck I sold a year ago. The mains are old school NHT towers, 2.something.... They are 3-ways but they only have 8" woofers and in our living room they just can't keep up. I just have an NAD preamp with a Carver THX 200wt/ch amp - stuff I got 20+ yrs ago when I was single and had money... My DVD player has pre-amp outs for all surroud channels including sub. The level is only set by ear.
The living room is about 31ft x 18ft with 9ft ceilings. TV on one end and fireplace on the other, both along the same wall and the opposing wall completly open on each end so it's very open. Where we sit is about 8ft from each main and the sub sits in a small corner to the back right also about 8ft away, about the middle of the wall. When looking at the TH I would like to confiure it vertically where the 10" are now an use the same 250wt plate amp. Shouldn't go much wider than about 18" if in the corner, but I could go deeper - like the sub is now.
As far as level/output, my wife says we have enough but the potential to have such capacity from a single 12" is crazy enough to pique my interest and want to build it anyway. I modeled my 10s (on another PC) and comparing the HT to it, I'll have about 6db more @ 10hz lower
Mean 12" TC based subwoofer. Thoughts for HT use? hispls Subwoofers 22 5th November 2012 03:02 PM
wtd 8 10 or 12" driver/s for HT sub. needmorstuff Swap Meet 10 10th August 2009 06:09 PM
cheap pyle 12" HT sub 250w? jol50 Subwoofers 1 8th February 2008 04:34 AM
please check my winisd numbers pne123 Multi-Way 3 24th January 2004 03:27 AM
HT: scale 10" sub cabinet for 12" driver? bbaker6212 Multi-Way 9 8th May 2003 06:54 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright ©1999-2014 diyAudio
