Old 19th March 2014, 01:00 AM   #1
Default Another TH driver...?
I present the Pioneer TSW 1200 PRO.
MSRP is $200, but it can be found for less than half of that.
It will do a clean 40 Hz in approx. 100 l (net) TH. And it's DVC, so you can wire it down to 2 ohms .
t/s params:
Sd: 531 cm^2
Fs = 40 Hz
Qes = 0.39
Qms = 10.7
Vas = 45.4 l
Xmax = 6mm
www.diysubwoofers.org
Old 6th April 2014, 05:36 AM   #2
Matthew Morgan J's Avatar
Looks GREAT to me Brian! I'm surprised you didn't get any responses on this interesting driver ...
Here are some inputs (single cab) and graphs (two tiny cabs in halfspace) for a TH based on the Pioneer TSW 1200PRO .... Looks good for highly portable, affordable but potent PA use solid and flat right down to 40hz .... This is a heck of a lot of motor strength for a 12" driver!
Equivalent BL figures are 25T at 8 ohms (7 ohms DCR) , 18.5T at 4ohms (3.5 ohms DCR) and 12.6T at 2 ohms (1.75T) , thats an incredible value in motor strength for only 99 bucks! =)
Old 8th April 2014, 04:15 PM   #3
6mm Xmax doesn't seem to be a real sub, but I guess for the price it's not bad.
Old 8th April 2014, 06:35 PM   #4
GM is online now GM  United States
GM's Avatar
Is there a ~$200 driver that does at least ~123 dB from ~35 Hz - up with 700 W in < ~140 L? If not, then maybe a pair of these will at least be good bang/buck.
GM
File Type: txt PioPro1200_DTS.txt (961 Bytes, 8 views)
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 8th April 2014, 08:52 PM   #5
Djim is offline Djim  Netherlands
Hi GM,
In Europe we have the Thomann The Box 12-280/8-W which costs 49
Windows 8, installing no signature driver solution e.g. EDEL USB Driver UMarcus PC Based 1 5th November 2012 05:39 PM
Driver Simulation Software (actual driver, not box) qingcong Software Tools 5 14th May 2012 08:41 PM
L-pad attenuator for midrange driver 6 1/4 inch driver rhythmdiy Multi-Way 0 4th November 2007 03:32 PM
FS: Silver Iris Coaxial 15" driver pair (sans XO and compression driver) theAnonymous1 Swap Meet 0 24th April 2007 12:09 AM
mtm versus tm driver recommendations on project with $500 driver and xo part limit gsattler Multi-Way 4 20th May 2002 05:54 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
