Subwoofer plate amp high level output and sound quality - diyAudio
Old 8th March 2014, 06:53 PM   #1
Default Subwoofer plate amp high level output and sound quality
Hi everyone, on my line arrays I have a plate amp for each that powers two 8's per tower. I use speaker level connections to send them a signal (shared signal for the power amp for highs/mids).
Is there an optimal way to do this? I also have the option to use high level outputs on the plate amp but I am worried this will introduce unwanted impedance, noise, etc. I am not an EE so my understanding of plate amps is very limited. I can draw a diagram of what I am trying to do if that will help. Thanks!
Old 9th March 2014, 04:53 AM   #2
Inductor's Avatar
The best way to send signal is trough XLR balanced cable/inputs to the amps (pro/amps and long distances like in studios and PA's).
Balanced audio - Wikipedia, the free encyclopedia
XLR connector - Wikipedia, the free encyclopedia
Old 9th March 2014, 07:48 AM   #3
Let me rephrase this...my plate amp on my towers do not have XLR inputs. I do not have RCA preamp outputs to use from my receiver to send to it. So I am using the high level inputs. This gives me the option to feed the high level outputs to the inputs fr the mids/tweeters or split the high level signal between the plate amp and the mids/tweeters. My overall question is, will routing the high level signal through the plate amp compromise the sound quality for the mids/tweeters?
Old 9th March 2014, 09:06 AM   #4
As you have the hardware there already and there's only 2 possible configuration options, why not just try them both and see which you prefer?
Old 9th March 2014, 06:16 PM   #5
I was hoping to know more about the science behind the options but looks I will be digging out my multimeter today
Old 9th March 2014, 06:33 PM   #6
Not much science there.
If you use the preamp outputs, you skip one stage with many components, which is good (in theory). In practice not much of an issue.
The bigger issue in using the plate amp in parallel with the sats is that you cannot use the active crossover for the sats. That will make the integration between sub and sats difficult. A passive crossover for the sats will produce other issues.
The best solution for you will be to buy or make an XLR-out to RCA-in adapter.
If you've always done it like that, then it's probably wrong. (Henry Ford)
Old 9th March 2014, 07:11 PM   #7
Where will I get the XLR output? There is no XLR anywhere in my system...
Old 10th March 2014, 05:42 PM   #8
Probably misunderstood your post #3. The first two sentences sounded as if.
Maybe you should post a pic or a drawing. If I understand your first post correctly, the plate amp has high-level inputs, which you connected in parallel to the sats. And it also has high-level outputs that make you wonder whether it is better to connect the sats there instead?
Old 10th March 2014, 05:45 PM   #9
This is exactly correct.
Old 10th March 2014, 06:34 PM   #10
Those high level outs may have a capacitor in series with the input, or not; your meter will tell you when you check continuity between high in and high out.
Level-dependend Sound Quality by certainly Bass Drivers - very bad sound at low level tiefbassuebertr Subwoofers 11 3rd March 2012 10:54 AM
Level-dependend Sound Quality by certainly Bass Drivers - very bad sound at low level tiefbassuebertr Multi-Way 1 2nd April 2010 04:12 AM
quality of high pass section of a plate amp pforeman Full Range 6 27th May 2009 03:44 AM
FS/WTT: Older quality Kenwood stereo amplifier for Subwoofer Plate amp mtnickel Swap Meet 1 7th January 2007 03:22 AM
My subwoofer plate amp passing high freq muhy3 Subwoofers 3 11th February 2005 12:52 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
