why ported and why sealed for a given driver?
Old 4th March 2014, 10:58 PM   #31
Cal Weldon is offline Cal Weldon  Canada
Speakerholic
Cal Weldon's Avatar
Basalt mineral wool does not pose the same hazard as glass wool. For every article you find that says it is, I'll find you two that says it isn't
Beside, errant fibres are easy to deal with.
planet10 needs your help:
Let's help Ruth and Dave
Old 5th March 2014, 12:48 AM   #32
ubza1234 is offline ubza1234  Australia
I bet those fine particles could find their way through the spider to the voice coil to..
so does the dampening sort of cancel out the springyness of the Air? I'm talking about a plain sealed box, no filling fluff.
Old 5th March 2014, 12:55 AM   #33
laplace is offline laplace  Australia
It's not a matter of cancelling. The force on the cone is the sum of the spring-force due to the box pressure increasing, and the resistive damping force. Adding damping increases the resistive damping force, which lowers Q and makes the system ring less. It does not reduce or cancel out the spring force, it changes the ratio of the two forces.
Open-Source F/Stop Timer
on flickr
Old 5th March 2014, 04:48 AM   #34
KaffiMann is offline KaffiMann  Norway
KaffiMann's Avatar
I like just having a very thin sheet of felt surrounding the rear of the driver to make sure it's all neat'n'tidy.
I also tried stuffing a t-tqwt with ikea pillows, ended up using a single layer of 2cm thick wool felt in the bottom part, much cleaner sound.
why ported and why sealed for a given driver?Hide this!Advertise here!
Sealed vs Ported sub?? Kingnoob Subwoofers 48 18th July 2015 08:29 AM
sealed or ported mlr Subwoofers 20 25th March 2012 05:18 AM
SEALED OR PORTED?! carshateme Car Audio 6 11th October 2011 06:28 PM
sealed vs. ported sonu Multi-Way 25 9th May 2005 01:50 PM
Would ported or sealed enclosure be best for this driver in small PA system? The Paulinator Multi-Way 26 25th April 2004 04:38 AM
Copyright ©1999-2017 diyAudio
