Can i get some help please! - Page 2 - diyAudio
Old 27th February 2014, 12:29 PM   #11
masliko is offline masliko  Australia
Originally Posted by masliko View Post
thanks for the help.
Old 28th February 2014, 12:45 AM   #12
GM is offline GM  United States
GM's Avatar
You're welcome! Hmm, one doesn’t normally think of a TL as having a ‘punchy sound’, but more a high SQ sound [extremely well damped], though one could EQ it to suit, so looking forward to how this works out for you.
What is its design details?
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 28th February 2014, 01:59 AM   #13
GM
Hi again,basically the Tl is not happening now because the size of panels wouldn't fit into the sheets i bought
So i"m looking at a fourth order now,or going with the sealed box.I'm looking into designs now.
Do you think that this sub box would work with my sub?
http://www.youtube.com/watch?v=9QdAz...ature=youtu.be
What do you think of a single band pass?
Thanks for the help GM!
Old 28th February 2014, 06:20 AM   #14
GM's Avatar
No, much too small with a ‘one note’ ~5.5 dB peak at ~44.8 Hz and stuffing it all just converts it to ~ a sealed cab response.
‘Single’ band pass? Do you mean 4th order BP? The vent required will ideally need to be a large PR.
GM
Old 28th February 2014, 01:30 PM   #15
GM
yeah,what do you mean PR?
Old 28th February 2014, 02:30 PM   #16
Greebster's Avatar
PR = Passive Radiator
Old 28th February 2014, 02:41 PM   #17
GM's Avatar
Passive Radiator...... the vent needs to be so long to have a low power compression that it will have audible pipe organ harmonics 'singing' along to 'color' its response, so a large, high excursion 'driver' is required and ideally two should be used in a bipolar layout to ~cancel out their high excursion vibration modes.
GM
Old 1st March 2014, 02:39 AM   #18
hey Down Under!
Reading what you posted, I don't think you should make a band pass. It will most likely sound boomy, as that is the nature of band pass.
Sealed is generally a safe bet, especially for higher Q drivers.
Ported can still work but you need a big cabinet tuned very low meaning big and long ports or a shelf port. without calculating, I don't think that really fits your 20" cube.
Old 1st March 2014, 06:06 AM   #19
Inductor's Avatar
Default Dayton Audio RSS315HFA-8 12"
The 4th order bandpass will give you essentially more output in the sub LF <50Hz region (40Hz 30Hz and 20's Hz).
For that you will need to build an enclosure that will be V1 = 36.5 L and V2 = 24.5 L with a total (net) of 61 L + port dimensions.
61L = 2.15ft³
File Type: jpg SUBS DAYTON RSS315HFA-8 is a 4th order bandpass.jpg (140.1 KB, 17 views)
Copyright ©1999-2017 diyAudio
