Good 8" drivers for Tapped horns with long path lengths? - Page 3 - diyAudio
Old 14th February 2014, 01:43 AM   #21
sine143 is offline sine143  United States
I know you know a lot more than me brian, so please dont take anything I'm saying the wrong way, its your knowledge and a that of a number of others here thats basically taught me anything.
as far as the resonances go, one of the most well regarded DIY low tuned THs available in these parts (gjallerhorn) displays the same problems, with 3 peaks almost 10 db up from passband average (the lowest being at 65 hz, WAY in the passband).
Gjallerhorn
the TH Spud itself displays a similar, 10 db jump, starting at 75hz and continuing above 110 hz.
Dual 8" tapped horn = TH-SPUD
So I dont see how this is a major design flaw? I actually tried to design it to push the spikes outside of the passband (instead of inside around 70 to 80 like seen in those 2 examples.
Old 14th February 2014, 05:22 AM   #22
I didn't say it was a "design flaw". I said that it would need quite a bit of processing to deal with it. e.g. a simple 12dB/oct low-pass filter may not be enough to get the best results.
www.diysubwoofers.org
Old 14th February 2014, 05:02 PM   #23
oh, I wouldn use anything wiith less than 24 db/oct slope. LR filter willhelp take down some of the peaks at xover point ast well.
Old 14th February 2014, 08:18 PM   #24
JLH is offline JLH  United States
JLH's Avatar
thanks for that link TB (sorry, my six key doesnt work so I'll never be able to spell your name out lol). I've been looking for it.
The THspud seems to dig a bit lower than I need, and is about 375 liters for 2 8s, I'd like to stuff 4 8s in that space if possible. I realize I'll likely only be able to get response down to about 20 to 25hz rather than the 15 or so hz the spud goes to. It has like a six hundred and 20 cm path length, about 150 more cm than I think I am really willing to go.
I dont think I can beat the spud, but then again i'm not trying to compete with it ;p
GM, I missed your second post. checking it out now!!!!
Try this. It is a smaller TH-Spud style horn that still uses two Tang Band W8-740 drivers. An Erse 3.6mH coil helps flatten the response out.
Ah, how beautifully the orchestra sounds before a rain! In a dry sunny day there is no way for the instruments to sound this way!
Old 14th February 2014, 11:28 PM   #25
Oliver, the JBL gto804 seems good in your 140 liter design, capable of another 4db output (digs a tiny bit deeper too). a tiny bit smoother as well.
Old 16th February 2014, 01:38 PM   #26
JLH's Avatar
I worked out the folding for this horn. A few things changed due to practical considerations and fitment requirements. The resulting Horn Response parameters reflect the required changes. The exterior dimensions are 11 5/16" (28.7cm) deep X 27" (68.7cm) wide X 38" (96.3cm) tall. Total folded volume is 6.7 cu. ft. or 189.86 liters. I think this is a lot of horn in a pretty reasonable sized package. Panel thickness used is 19mm or . An Erse 3.6mH coil is added and the Tang Band W8-740 woofers are wired in series for an 8 ohm load. An amplifier capable of 500Wrms into 8 ohms should be more than enough. Its Max SPL level well exceeds THX standards. I'm seriously considerenig building a pair of these once the weather clears up.
Old 16th February 2014, 02:02 PM   #27
Switch the expansion from "CON" to "PAR" for a more accurate sim of a horn folded up into a rectangular box.
Old 16th February 2014, 05:03 PM   #28
JLH's Avatar
I tried your suggestion. It virtually made no difference. I can barely see the difference when I do the "compare previous" command. Historically, my Horn Response predictions have measured very close using Conical sections for the simulation. Is there a significant reason for your suggestion? Did I miss a conversation somewhere?
Old 16th February 2014, 05:28 PM   #29
JLH, your sim is nice (very flat), but it seems to have VERY similar output capabilities to a half of the sime I posted on page one (Good 8" drivers for Tapped horns with long path lengths? (I posted a 4 driver design, by showing graphs of 2 2p designs in 2S).
They are withing about 1 db of each other if both are graphed in 1 pi, and are the same size (140 liters pre fold).
the conical vs Par thing might be more relevant when working with a larger horn.
Old 16th February 2014, 06:01 PM   #30
Expansion in a horn which has two parallel sides (basically almost every horn folded into a rectangular enclosure) is parabolic, not conical. A search for "parabolic" on this forum should turn up the message threads where this has been discussed.
Playing hornresp : 22L tapped horns 30-180hz with 10" speaker papasteack Subwoofers 21 13th March 2013 11:12 AM
One 15" Tapped Horn vs Four 8" Tapped Horns Patrick Bateman Subwoofers 28 12th February 2013 10:12 AM
Long Preamp to Power Amp Cable Lengths Loren42 Tubes / Valves 53 22nd January 2013 02:07 AM
Supravox bass drivers a good match for front horns? Bill poster Multi-Way 16 5th October 2010 09:46 AM
Photos of completed Tapped horns, from "Collaborative TH" thread neddludd Subwoofers 3 3rd May 2010 11:36 PM
Copyright 1999-2017 diyAudio
