Good 8" drivers for Tapped horns with long path lengths? - Page 2 - diyAudio
Old 13th February 2014, 07:28 PM   #11
tb46 is offline tb46  United States
Hi sine143,
The TH-SPUD is hard to beat:
Dual 8" tapped horn = TH-SPUD
At least it is a good starting point. I think it was jbell who squeezed the 55-2421 up to 8:1, and it stll survived. :-) I would not go past 3 or 4 :1.
Oliver
Old 13th February 2014, 07:41 PM   #12
sine143 is offline sine143  United States
thanks for that link TB (sorry, my six key doesnt work so I'll never be able to spell your name out lol). I've been looking for it.
The THspud seems to dig a bit lower than I need, and is about 375 liters for 2 8s, I'd like to stuff 4 8s in that space if possible. I realize I'll likely only be able to get response down to about 20 to 25hz rather than the 15 or so hz the spud goes to. It has like a six hundred and 20 cm path length, about 150 more cm than I think I am really willing to go.
I dont think I can beat the spud, but then again i'm not trying to compete with it ;p
GM, I missed your second post. checking it out now!!!!
Old 13th February 2014, 07:53 PM   #13
GM, your design is the MCM 8 correct? doesnt it only have 8mm of xmax?
Old 13th February 2014, 08:31 PM   #14
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
I'm no expert, and I do not intend to sound harsh, but not sure I would do that
sometimes we know very little, and sometimes we know too much
Old 13th February 2014, 08:33 PM   #15
yeah me either. friend askes specifically about something that would fit snug in a corner, firing into said corner, so I sketched that up. I also sketched up something similar with a slightly different fold internally (same picture, just slightly messed with one side of the fold, the right side, to squeeze some more path length and eliminate some deadspace)
Old 13th February 2014, 08:36 PM   #16
Hi sine143,
I didn't mean to copy that one. I just like some of the design ideas.
I'll attach the Hornresp Export file for one I drew up (w/o an actual detailed drawing it's just all guesswork anyhow) prior to stuffing being available in Hornresp, I added stuffing and filters here:
File Type: txt 144L_MCM.txt (950 Bytes, 11 views)
Oliver
Old 13th February 2014, 09:24 PM   #17
TB, thats a lot like what my sims with the mcm 8 were looking like too, some wobble across passband with a nasty high end.
heres my comparison with the anarchy woofer (dual driver) vs your mcm 8 dual driver, in about 145liters each. The anarchy woofer needs about a 22hz hipass (mainly due to lower SD imo), where as the mcm needs about a 19 hz hipass, so the mcm digs a bit lower (19hz is below the bandpass of the sub so it doesnt really affect response). Both designs exceed xmax inside pass band (12mm for anarchy, 8mm for mcm), so no jiggling of hipass settings will help them there.
EDIT, forgot to attach image lol.
Old 13th February 2014, 11:37 PM   #18
That out of band noise starts right after the passband and is around 10dB higher than it. That's going to require quite a bit of processing to effectively deal with it.
www.diysubwoofers.org
Old 13th February 2014, 11:58 PM   #19
Lower than 85hz peak and 120hz peak shown on the mcm dual 8 graph, and the anarchy is more sensiive in pass band so that mess has less gain comparitavly. Suppossedly hornresp exaggerates the peaks as well but wont know till its built lol
Old 14th February 2014, 01:16 AM   #20
Not that much. See my sim'd vs. measured results here:
The Subwoofer DIY Page v1.1 - Projects : "Proof of Concept #3"
Note - the sharp dip around 220 Hz is likely because I didn't use any reflectors in the box, or maybe some other resonance in the box not predicted by HornResp. Now, if I had mad box skillz I would have tried to engineer that resonance to be around 140 Hz to null that little peak out, but alas...
The out of band resonances don't seem to be so high compared to passband when I sim THs with larger drivers. Maybe POC #3 is going to be based around a 15" driver instead...
Playing hornresp : 22L tapped horns 30-180hz with 10" speaker papasteack Subwoofers 21 13th March 2013 11:12 AM
One 15" Tapped Horn vs Four 8" Tapped Horns Patrick Bateman Subwoofers 28 12th February 2013 10:12 AM
Long Preamp to Power Amp Cable Lengths Loren42 Tubes / Valves 53 22nd January 2013 02:07 AM
Supravox bass drivers a good match for front horns? Bill poster Multi-Way 16 5th October 2010 09:46 AM
Photos of completed Tapped horns, from "Collaborative TH" thread neddludd Subwoofers 3 3rd May 2010 11:36 PM
Copyright 1999-2017 diyAudio
