Old 31st December 2003, 01:13 PM   #1
Banned
Default 12" Titanic Mkiii Subwoofer Kit
Does anyone know where in Australia can you buy a 12" TITANIC MKIII SUBWOOFER KIT
http://www.partsexpress.com/pe/showd...D=167008&DID=7
Old 1st January 2004, 05:22 AM   #2
paulspencer's Avatar
Nic,
I haven't found any source in Australia and I doubt you will find it. You can get it from Parts Express, but expect to wait 3 months unless you are prepared to pay for air freight. I think the Titanic driver will cost you about $380 IIRC. On the other hand, you can get the Shiva here in Oz for $300 or if you are clever you can get the Peerless XLS for $220, both worth considering.
regards,
Paul
Old 1st January 2004, 06:37 AM   #3
Banned
Default Where can you but these kits from
Old 1st January 2004, 09:23 AM   #4
You really don't need a kit to build a subwoofer. They are very simple. Get a plate amp, a good driver, choose and alignment, build a box. Copy a similar sub if you like, it is quite easy. Not like full range speakers where you need to design a crossover.
What are your goals?
I can show you a few examples. You can use other drivers (as I have), but you will have to pay for shipping and wait 3 months for them to arrive
cheers,
Paul
Old 1st January 2004, 10:18 AM   #5
Banned
Default Dayton
Im think the SW250 Dayton Kit that loudspeaker.com sells. Are these any good?
Old 1st January 2004, 10:25 AM   #6
You are in Australia, right?
If so, start with drivers you can get here!
It's hard to make suggestions without knowing your goals? Output, extension, music/HT etc
regards,
Paul
Old 1st January 2004, 11:45 AM   #7
Banned
Default Thoughts
Its for Home Theatre. I like tight bass, not boomy, I want a sealed enclosure. I am going to have a system with 6.5" main and centre speakers.
Old 1st January 2004, 12:45 PM   #8
Banned
Send a message via MSN to SkinnyBoy
Default Re: Thoughts
don't go sealed..
Old 1st January 2004, 02:30 PM   #9
Nic,
I'll make a few suggestions, based on drivers you can get in Australia.
Peerless XLS - a very good driver used in quite a few comercial subwoofers, as well as DIY projects. There are two good examples of sealed subwoofers using this driver, with good info.
http://members.ozemail.com.au/~joeras/sub_index.htm
Linkwitz has also made a similar sub:
http://www.linkwitzlab.com/thor-intro.htm
This driver is generally best sealed or with a passive radiator. It is very difficult to design a vented box for this driver. Here is a passive radiator version:
http://www.geocities.com/adrian_mack/
or there is the Shiva, which is a little more flexible in that it is easier to design a vented alignment with the Shiva. The Shiva does tend to need a bigger box, but it has a balance of parameters that is preferred by many.
I see no reason to so quickly jump to a sealed sub if the application is home theatre. You give up at least 6db of output and considerable bass extension which will reduce the impact of LFE that most want a subwoofer for in HT use. Either you are willing to give up output, or get a driver with a big xmax to get decent low frequency output in a sealed box, if you go sealed.
hope this helps,
regards,
Paul
Old 1st January 2004, 02:39 PM   #10
Banned
Default Thanks
Thanks for your advice mate
Dayton Titanic MkIII 15" sub bottom out chainenoble Subwoofers 18 13th December 2010 04:59 PM
Titanic Sub 12" MKiii gengis Swap Meet 5 24th November 2006 02:34 PM
faceplate 15" TITANIC MKIII SUBWOOFER chainenoble Subwoofers 1 16th April 2006 02:26 AM
TITANIC 15" MKIII SUBWOOFER vented enclosure oachalon Subwoofers 2 12th September 2005 04:58 AM
Titanic MkIII 15" Wingfeather Subwoofers 10 8th November 2004 06:36 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
