Finished my Maelstrom Sonotube after almost a year of work - diyAudio
Old 30th December 2003, 11:27 PM   #1
kingdaddy's Avatar
Default Finished my Maelstrom Sonotube after almost a year of work
I posted about this subwoofer project earlier this year with some pictures of the construction and a description of an idea for a closeable port. So I went on a journey to have a Port Valve turned from Oak. Well the guy who was going to do the turning gave up on me so I went and bought a lathe and did it my self. I’m actually glad I got the lathe, beside it being a lot of fun I was able to get the valve just the way I wanted it and the valve seat fits so tight that I will only need a thin gasket to finish the seal, so I’m very happy with the functionality of the entire Vale mechanism, it works very smooth and only a few twists of the knob and the Valve is closed very tight.
Besides the 5 month delay to get an acceptable Port Valve turned the project so far has taken about 300 hours over 4months and cost about $1200 US for each of the 2 Maelstrom 18” Sonotubes. I still have a few details to finish but this one is ready to go into the listening room. Next I will silkscreen the plate behind the Valve knob with a placard that will show the “Open” and “Close” position, and a felt gasket on the valve seat to complete the seal. The prototype worked very well so I’ve already had many hours to listen to a working version of the port valve in a real world situation, and it does work very well to tighten up the bass when the valve is closed, pulse it’s somewhat decorative and functional as a display shelf. Now all I have to do is fix all the rattles in the house that just one of these has brought to my attention. Hopefully early this New Year I will have both subs in the listening room and have the BFD E.Q. set up properly.
Old 30th December 2003, 11:28 PM   #2
kingdaddy's Avatar
Default Port Valve Closed for Music
A pic with the Valve closed
Old 30th December 2003, 11:30 PM   #3
kingdaddy's Avatar
And the bottom showing the Maelstrom 18" driver.
Old 30th December 2003, 11:33 PM   #4
kingdaddy's Avatar
And the unfinished valve knob, locatated at the front of the sub.
Old 31st December 2003, 01:14 AM   #5
diyAudio Moderator Emeritus
roddyama's Avatar
You are indeed the KingDaddy. That's a totally awesome and unique sub. And to your neighbors, be afraid, be very afraid.
Rodd Yamashita
Old 31st December 2003, 02:24 AM   #6
kingdaddy's Avatar
Here is the Mack Truck window crank mechanism that moves the Port Valve.
Old 31st December 2003, 02:26 AM   #7
kingdaddy's Avatar
And the Woofer Mod that was necessary to keep the port valve stem perpendicular to the center of the port opening.
Old 31st December 2003, 02:27 AM   #8
Timn8ter's Avatar
I remember when you first proposed the idea. I'm very impressed with your perseverence to see it through to fruition.
Old 31st December 2003, 02:38 AM   #9
SY's Avatar
Awesome. This is DIY at its best. Any response or impedance measurements yet?
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 31st December 2003, 03:34 AM   #10
Variac is online now Variac  Costa Rica
diyAudio Editor
Variac's Avatar
a 5 angle valve grind might give you better flow
You could also just have a threaded rod at the end of the valve stem and spin it down to close it, but all that spinning is a lot of work!
Are you closing it to try intermediate tunings?In other words does the bass slowly tighten up as you close it?
Also keeps the cats out.
"The geek shall inherit the earth"
Burning Amp thread here on diyAudio [/B]
FS: 2x Maelstrom-X Subwoofers chrismercurio Swap Meet 0 2nd April 2009 07:33 PM
Aleph-X finished... one year ago !!! GlouBou Pass Labs 6 30th June 2006 04:40 AM
Center Channel Project finished after nearly a year of work. kingdaddy Multi-Way 8 29th November 2005 01:48 PM
Will a sonotube sub work in a car? S.C Subwoofers 14 9th June 2004 03:39 PM
Sonotube Port Valve Prototype finished (pics) kingdaddy Multi-Way 2 7th June 2003 07:55 PM
Copyright ©1999-2017 diyAudio
