The Lab12 PA Subwoofer Smack Down/Death Match - Page 5 - diyAudio
Old 11th February 2014, 10:06 PM   #41
Originally Posted by weltersys View Post
What was the Xmax of the previous drivers?
Published Xmax for them is 12mm. From observation, it looks like the suspension brings the cone to halt not much longer after that.
www.diysubwoofers.org
Old 11th February 2014, 10:19 PM   #42
Originally Posted by Patrick Bateman View Post
^^^ This pic says a lot. You can see the Alpine's 70mm of xmech is no joke. I see a lot of car audio drivers where they slap a huge surround on a woofer to give the impression that it has a lot of xmax, but then you flip it over and the woofer is 5" deep. The Alpine Type R eights are nearly as deep as they are wide.
The driver pictured next to the Alpine 12D2 is the Infinity 122.7W. That's what I used previously in my car. Interesting driver, but not a match for the 12D2s. t/s parameters suggest that it's a better fit for a sealed cab at home (F3 around 30 Hz), but did reasonably well in-car. The suspension suggests it might be a better fit for a vented alignment (which is what I'll be trying them in next, in-house). Neo magnet motor (most of what you're seeing in the picture is the heat-sink for the motor), 3" voice coil and 350W RMS, 1.4kW peak rating. I got them for about $100 each.
Old 12th February 2014, 02:00 AM   #43
DHAA is offline DHAA  United States
DHAA's Avatar
http://support.alpine-usa.com/produc...01215_D4_2.pdf
IMHO, those Alpines are tough to beat. Even at $200-$300 each, they offer features that the Lab12 doesn't have. A flat BL curve and higher displacement. The higher FS is very useful for a tapped horn, as the bandwidth of a TH is highly influenced by the FS of the driver. Basically a driver with an FS of 22hz tends to work well in a sub-20hz TH, and that's often more sub-bass than you need for music.
SWS-15D4 : $129 delivered(!)
Also Mr. Bateman, in post #50 of Alpine SWS-15D2 Tapped Horn you also commented on the Alpine 15", saying:
One thing that I'm exploring is whether front loaded horns have more 'impact' than THs and BLHs. I've read this on forums, so I'm building a FLH with a TC Sounds eight to find out. The Alpine 15" would make a great candidate for a big FLH. In fact, it's probably better suited for a FLH than a TH, unless you need ultra low LFE (which you might, depends on application.)
When I first started experimenting with Hornresp, I found it amusing to substitute different drivers in existing designs to see how well they worked. I had tried a lot of the Alpine and Infinity "auto sound" subwoofers, and got some funky response curves - which I now realize that the designs I substituted them into were really optimized for a higher Fs driver.
But your comment above that the Alpine 15" may be better suited for a FLH instead of a TH spurred me to try a new idea over the weekend. Go ahead and laugh, but here is my first attempt at a FLH. I didn't put a lot of thought into it, just played around with the "Loudspeaker Wizard" until I got something that didn't look too ugly. I would appreciate you thoughts on this. Thanks.
Old 12th February 2014, 03:13 AM   #44
Patrick Bateman's Avatar
Fifteens need a big box; so using the same parameters there wasn't a whole lot I could do. But on the upside you can't do a lot better in this footprint!
Enlarging the back chamber extends the low bass a bit, reduces that low frequency peak, but at the expense of a bit higher displacement. But with a highpass at 30hz you won't hit it excursion limits. Without a highpass you'll exceed them by a single millimeter, which probably won't do anything to a driver with an xmech of 70mm.
Move the highpass to 40hz and you could probably double the power handling.
Old 12th February 2014, 06:42 AM   #45
sine143 is offline sine143  United States
patrick, your s12 segment is too small for a 15
Old 12th February 2014, 07:21 AM   #46
DHAA, you want the response shape of a FLH to slope the other direction generally, because FLHs exhibit a unique trait, when you add more cabs to the stack (or wall/corner load) the low frequency droop is "filled in".
Heres my take on the driver keeping with the 340 liter parameter. as you can see in the picture, it will take about 60v before exceeding xmax (35hz filter for 1 cab, 30hz filter for 4 or more cabs). I've shown the response for 1 cab (standard FLH "rising response" as freq increases), and 8 cabs (pretty darn flat)
The Alpine seems to like a lower compression ratio (helps fill in the 70 to 100 range).
this is a quick 10 min sim.
however, givin 340 liters, you can get within a db of this sim with the lab12 driver with 300 watts per box (45volts) (vs the almost 1000 per box the alpine will take)
Old 12th February 2014, 03:47 PM   #47
DHAA's Avatar
Thanks Mr. Bateman and Mr. 143 for you comments - they were very helpful.
How can you tell that - is there a particular TS spec. you are looking at? Thanks.
Old 12th February 2014, 06:10 PM   #48
weltersys's Avatar
You can tell by comparison-sine143's sim using a lower compression ratio than Bateman's (or yours) has a smoother response in the 70-100 Hz range, but a slight reduction in the low frequency.
Old 12th February 2014, 06:18 PM   #49
Yeah, pretty much just trial and error. with a higher compression ratio it was basically impossible to fill in that gap in the 70 to 100 range, and as you saw, it required a slightly larger rear chamber (as per PBs sim). with a lower compression ratio and a slightly smaller rear chamber I was able to fill that section in (significantly I might add) and only sacrifice about a db of sensitivity down low (Which is compensated for as soon as you add multiple cabs, considering the mouth on my horn is larger than those on yours or patricks).
Old 20th March 2014, 02:27 PM   #50
Guys,
Seems like most of your discussion here have evolve around either car or PA applications. I have a pair of Lab 12's and am curious about using them in small enclosure, push pull configuration. I've looked around a bit and haven't found anything specifically addressing this approach. Any thread suggestions or insights would be appreciated.
Thank you.
tube driven subwoofer...25w death box? gsdurrant Subwoofers 2 20th August 2013 02:29 AM
FS: Eminence Lab12 Generation II 12" Subwoofer Derrick Swap Meet 0 25th October 2008 05:53 PM
PA Subwoofer suchuwato Subwoofers 22 30th September 2008 03:48 PM
Suitable subwoofer to match FRS 8 Cyburg's Needle stobiepole Full Range 1 22nd December 2005 10:14 AM
Copyright 1999-2017 diyAudio
