H/T sub box help - diyAudio
Old 16th January 2014, 08:34 AM   #1
Default H/T sub box help
have a 12" driver with these params-
re-6.839 ohms
Fs-23.55Hz
Qts-.39
Qes-.436
Qms-3.682
Le-1.576mH
Mms-125.5
Vas-192.1l
spl 89.49db
will be using A 150W plate amp
could someone with bassbox help me out with an enclosure 4 this/
will be using sonotube,so just box volume and port dimensions would be great
txs in advance
mm
Old 16th January 2014, 12:01 PM   #2
norman bates's Avatar
ideal 4th would be around 6ft3 tuned to 24hz.
But you can go a bit smaller.
Old 16th January 2014, 11:50 PM   #3
thank you
Old 17th January 2014, 01:05 AM   #4
GM is offline GM  United States
GM's Avatar
For 150 W, it ideally needs a 6" dia. vent x 17.5" long.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
ETON 7-372 HEX-B Box volume need?box drawing wuxinghui2013 Multi-Way 1 23rd December 2013 03:16 PM
In Bass reflex box (vented)-If I make smaller box than what consequences will I have? eliaselias_0 Multi-Way 6 3rd January 2011 04:49 PM
Aperiodic box for B200. Vent size and box shape? ChuckT Full Range 11 15th October 2006 08:29 AM
Want to re-box several si t amps in one box. How do I hook up to one power supply? ExJxC Class D 7 22nd September 2005 10:27 PM
High voltage umbilical and connectors / 1 box for PSU 1 box for amplifier in kit88 PTSOUNDLAB Tubes / Valves 30 10th September 2003 08:45 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
