Sub DSP recommendation
Old 8th January 2014, 04:50 PM   #1
wyan is offline wyan
Default Sub DSP recommendation
Dear all,
I am thinking to buy a DSP for subwoofer project. The requirements are:
1) Flexible low pass filter. Typical crossover option at 80HZ and below is fine; it will be better if it stretch a bit higher.
2) Subsonic filter for protection.
3) Bass boost. Graphic eq (or multiple EQ points) is even better.
4) Transparent and little loss in dynamics.
Any recommendations? (Including DIY project/groupbuy)
Thanks.
WYAN
Old 8th January 2014, 05:22 PM   #2
TundraLTD is offline TundraLTD  United States
TundraLTD's Avatar
DSP
miniDSP in a BOX | MiniDSP
DSP with amp
PWR-ICE125 | MiniDSP
Old 9th January 2014, 04:51 AM   #3
bitSmasher is online now bitSmasher  Australia
bitSmasher's Avatar
Buy a uMik at the same time as the MiniDSP, that'll keep you busy (and neighbours annoyed) for a while!
Old 9th January 2014, 11:01 AM   #4
OllBoll is offline OllBoll  Sweden
Hypex also has plate amps:
AS2.100 Digital 2x100W and the bigger brother PSC2.400d for 2x400W. There is an even bigger one but I don't think you need 2x700 W =)
They can all be bridged into one channel if you don't need two. If you don't need digital input they have analogue input only versions that are slightly cheaper.
Old 3rd February 2014, 07:08 PM   #5
kgveteran is offline kgveteran  United States
I've owned my MiniDSP for some time now, its a 2X4 balanced with advanced plugins..... Using that along with my OmniMic is really amazing for the price...
Old 3rd February 2014, 10:52 PM   #6
a_rabid_monkey is offline a_rabid_monkey  United States
4th for the minidsp. I used it when I had a pair of DTS-10's and it worked wonders.
I went the way of an ECM8000 and a Roland Quad-Capture for measuring though. A bit more expensive, but I wanted the extra flexibility to do other things with it.
Old 5th February 2014, 01:33 PM   #7
Yup, the days of ploping down a sub, connecting it and hoping are gone. With even a $300 investment, you can finally see why it sounds so terrible, and why the two ton fishtank has to be moved, cause the sub sounds better there
Sub DSP recommendationHide this!Advertise here!
First 3.1 w/ DSP broncosaurs Multi-Way 9 3rd June 2013 03:10 PM
New to DSP Ridin '24'z Digital Source 5 12th May 2010 01:33 PM
RS-232 cable for DSP-Amp Digisynthetic DSP-1400 Sabbelbacke Parts 0 9th May 2009 09:33 AM
DSP's, Which one? StuartH Digital Source 2 17th October 2003 06:01 AM
DSP theory hifiZen Digital Source 7 6th November 2001 06:18 AM
