Why were so few of these made ? - diyAudio
Old 5th January 2014, 01:31 AM   #1
nigelwright7557's Avatar
Default Why were so few of these made ?
We used a pair of these but in orange vinyl on a disco in 1979.
This was the only time I have ever seen this type of speaker.
I think it was called a folded horn, but I could be wrong.
Old 5th January 2014, 04:15 AM   #2
Top Shelf's Avatar
Looks like a classic "w" bin. Apparently not ported though ? They had a short path length so they really only had a higher cutoff > 50hz.
JEREMY M_________________________________
I like it loud, BUT NOT TOO LOUD!.... Hey do you hear that high pitched ringing sound ?
Old 5th January 2014, 04:28 AM   #3
I've seen quite a few of them here, some still in use.
It definitely looks like a "W" bin. And yes, the cutoff is likely quite high. Might have been good for 1979, but not today's pop and dance music.
www.diysubwoofers.org
Old 5th January 2014, 04:59 AM   #4
doctordata's Avatar
Default EV Eliminator 1
I had a pair of EV Eliminators 1A's in the 80s for my drive in . They were great on my Dynaco Stereo 400 and played very clean and VERY loud ! They sounded best in big halls .
Cheers ,
Rens
If you measure, you know; if you guess, you don't
Old 5th January 2014, 01:05 PM   #5
epa is offline epa  Netherlands
looks like this one
one good thing about music ,when it hit you feel no pain.
so hit me with music
. hr driver db
Old 5th January 2014, 04:26 PM   #6
When I think of a W bass horn, I recall something slightly different. 48" tall, front inside panels met at an edge, not a panel and the 15" woofer mounted from a panel in the rear facing forward into a slot. Could be they were called double folded horns too.
Old 5th January 2014, 04:47 PM   #7
Jsixis is offline Jsixis  United States
yep folded W bass bins, real loud at 70hz which happened to be where a lot of kick drum back in those days was tuned to.
Why not more? Too ******* heavy. Now we have lots of amps and electronic crossovers so 1 18 woofer is plenty.
I know nothing, so learning is really awesome.
Old 5th January 2014, 05:24 PM   #8
Probably originally meant for bass guitar since Orange make bass and guitar amps.
Ampeg used to make a similar W-bin for bass which was almost as loud as it was heavy.
To the best of my knowledge Orange amps and cabs always came in a choice of black or orange Tolex.
Old 5th January 2014, 09:01 PM   #9
chris661's Avatar
From what I can gather, these used to be really popular.
Lots of efficiency in the kick-range, so you could get the hit-in-the-chest feel from fairly modest power inputs. Good for installed nightclubs, but I wouldn't want to tour with them.
These days, as noted above, an 18" in a ported cabinet will go much louder at LF (<60Hz), but probably won't match up in the 100Hz range. Putting both together for a larger sound system would probably do quite well.
Chris
Old 6th January 2014, 07:53 AM   #10
freddi is offline freddi  United States
freddi's Avatar
Someone made a mistake!! ben04srt Car Audio 7 22nd February 2010 11:43 PM
How It's Made jlsem The Lounge 5 27th November 2007 04:45 AM
Never made anything before Moondog55 Chip Amps 5 3rd September 2007 03:45 PM
Home Made Tubes?? has anyone made one, is it possible?? John Biles Tubes / Valves 7 11th December 2005 02:29 AM
i made it...!!!!!!!!!!!!!!!!! tbla Everything Else 21 20th December 2002 05:46 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
