Old 2nd January 2014, 09:45 PM   #1
Default Where is this mythical subwoofer?
It is not uncommon to see the pyramid, or triangle. of things you can have in a sub woofer. but physics will only allow you to have two. never three.
Small size
Deep bass
Cheap.
So where is this mythical cheap deep bass in a large enclosure. Is this where tapped horns fit in? something like the kraken 2X12?
Old 2nd January 2014, 10:23 PM   #2
Check Parts Express for buyout speakers and dumpsters for free wood, create your own myth :^).
My tapped horn "Tub Sub" uses two $5 buyout 10" speakers, is 99 dB one watt one meter in half space at 60 Hz (open field) but located against the wall behind the outdoor hot tub, 24 Hz is only -3 dB from 60 Hz, with a "loudness contour" peak at 40 Hz.
Old 2nd January 2014, 11:28 PM   #3
SY's Avatar
The third leg is "efficient," not "cheap."
"The way to deal with superstition is not to be polite to it, but to tackle it with all arms, and so rout it, cripple it, and make it forever infamous and ridiculous."- H. L. Mencken
Old 3rd January 2014, 02:19 AM   #4
Five or so years ago there was a liquidation company selling off a TON of Bazooka returned merchandise, much of it with nothing wrong. $10 or so as I recall per 12" driver and several people put a couple dozen into a wall to good effect.
Old 3rd January 2014, 02:43 AM   #5
MemX is offline MemX  United States
Are we referring to Hoffman's Iron Law?
Old 3rd January 2014, 03:14 AM   #6
Well. I thought I was referring to that. Apparently where ever I had copied it from was incorrect. This was not intended to be a which sub is better thread. Or anything like that. I was just wondering if I was missing something that was right in front of my eyes, but it was so obvious I was overlooking it.
Old 3rd January 2014, 06:57 PM   #7
Hoffman's iron law: loud, low, or small-pick two.
If you don't mind spending a lot of money, you can have all three, but the box won't be efficient.
In general, modern sub drivers are being designed with more Xmax, allowing more output with less efficiency.
Old 5th January 2014, 06:11 AM   #8
Not sure I would say "general", cheap high powered digital amps fuel the small box high excursion varieties. Most likely due to the highest profit, easiest sell to the ignorant masses who may never realize that while it does play loud and will play low, it won't do loud and low at the same time.
I'd say most common sub continues to be a moderate sized ported box (or functionally same passive driver instead of a port).
High end are big boxes, some are horns, some are just big.
Old 6th January 2014, 03:39 AM   #9
badman is offline badman  United States
badman's Avatar
efficient, low, small, is the way that doesn't need qualifiers.
There are some solid inexpensive sub drivers out there. Zalytron's clearance 1201PL is a solid woofer for $20 per, less if you buy 8. They might need a little TLC to get the suspension back to "flat" but not much.
I write for www.enjoythemusic.com in the DIY section. You may find yourself getting a preview of a project in-progress. Be warned!
Old 8th January 2014, 02:28 AM   #10
Inductor's Avatar
So where is this mythical () deep bass in a large enclosure?...
Do you mean... SMALL enclosure?
Because that's where the magic is.
FS in Los Angeles: subwoofer, subwoofer cabinet, oscilliscope, KEF center... taloyd Swap Meet 9 11th March 2014 04:25 AM
Overview about words largest Subwoofer Drivers/Transducers (SUBWOOFER BEAST) tiefbassuebertr Subwoofers 27 9th September 2012 09:42 AM
FS: Dayton Reference Subwoofer RSS315HF-4 12" Subwoofer Driver matevana Swap Meet 0 12th February 2012 02:42 PM
Subwoofer build - Morel UW1258, 12" Ultimate Subwoofer mantha3 Subwoofers 46 10th October 2011 01:11 PM
how to connect a non powered subwoofer to a stereo system without a subwoofer output JSD777 Multi-Way 4 20th September 2005 03:19 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
