Sub recommendation.
Sub recommendation.
Old 13th February 2014, 03:21 PM   #61
Greebster is offline Greebster  United States
Greebster's Avatar
Originally Posted by giro1991 View Post
What is opinion on this from peerless themselves?
However one important feature of the closed box concept is that the "in-room" response can be flat to very low frequencies in a normal living room.
This is because there is a bass boost from the room by up to 12 dB/oct below the first standing wave. Equalization for flat anechoic response therefore leads to a low frequency boost that is not always desirable.
I probably will just build and enclosure and stick a peerless in, without EQing as Win ISD Pro is proving to be difficult, and perhaps leave the HPF out untill I do get LP deck see how that goes.
The quoted text above is incorrect. There is no room gain, only modal regions dominate in room response. Read up on Geddes multisub approach.
In my PITA room I have two distinct issues and a barrage of minors. The two main ones are a null @~32Hz of -15dB and an opposing peak @ ~50Hz of +9dB. Thats driving the sub flat that has a lower end response of 18Hz. Eq can help with the upper peak, but the lower one can only be addressed by either changing the room (impossible in my case, apt) or changing placement of the subs within it.
Old 13th February 2014, 04:34 PM   #62
chris661 is offline chris661  United Kingdom
chris661's Avatar
Are you sure?
The average measurement of a car shows a definite boost below ~50Hz. There's a graph of a load of different cars, but the trend is definitely there.
I think its safe to say that room gain isn't something to rely on, but is something to be glad about, if it does result in increased LF headroom.
Old 13th February 2014, 05:29 PM   #63
Greebster's Avatar
cars are horn shaped, is your room?
BTW there is no cabin gain in a van for the same reasons.
Old 13th February 2014, 05:30 PM   #64
weltersys is offline weltersys  United States
weltersys's Avatar
Originally Posted by chris661 View Post
Are you sure?
After testing, I'd agree with Greebster, unless your "room" happens to be as small as a car cabin, which is the equivalent to sitting inside of a large sealed bass enclosure.
A the listening position near the center of my 20'x11'x8' room, modes do happen to support low bass (below 40 Hz) better than some upper bass, but when the rear doors are opened, there is more LF than when closed.
If the room was experiencing "cabin gain" as in a car, the opposite would be true.
Art
Old 13th February 2014, 06:11 PM   #65
Greebster's Avatar
My room is 23' something by 13' something. One end is truncated to allow for the kitchen with a 18' hallway off the middle lengthwise. This makes for a real bad situation acoustically @ low frequencies. My system will have stereo bass multipoint, but is not worth having stereo bass in a room like this. I do plan to move.
Old 13th February 2014, 06:38 PM   #66
Greebster's Avatar
Art
Have taken notice with my car, for a stock stereo is quite nice, one of the full range woofers used in the back deck was dead, system sounded a bit anemic and replaced with CHEAP 6x9's "three ways" (lol) clipped the super tweeter leads and ran them that way. Impressive. Difference with windows up nearly blurs the vision. Pop the sunroof and or open the windows a bit and that low frequency pressurization (gain) is increasingly lost.
Also did a sound field check around the car with using AudioTool on my tablet and came to a couple indirect conclusions. 1. the bass is greater in front of the car than behind (by ear and measurement) (windows/sunroof open, rear windows up) using the interior like a large horn. 2. is acting cardioid or a combination of both. Didn't have the time for refined measurments, was at a friends home. Just one of those curiosity moments hit and couldn't help myself
Old 14th February 2014, 03:07 PM   #67
giro1991 is offline giro1991  Scotland
giro1991's Avatar
Browsing CPC I need to select components. More parameters than I anticipated again, such as voltage ratings etc
I got some ideas by referring to Active Filters page on ESP ...
Resistors should not be less than 2.2k, nor higher than 100k - 47k is better, but may not be suitable for very low frequencies ... All resistors should be 1% metal film ... Capacitance should be kept above 1nF if possible, and larger (within reason) is better ...
Capacitors should be polyester or Mylar
Not sure on voltage ratings though 50VDC or 50DC(?) would seem adequat seeing as line level is no more than 2.5v or so.
Michael Gerzon's Trifield decoder: foobar2000 plugin - free
Cheap 20bit ladder dac with 4 fs minimum phase filter TDA1306.pdf
Old 15th February 2014, 09:52 PM   #68
jagster is offline jagster  United States
Look at the Polks. Reasonably priced and very high quality. I just bought one factory direct in a gorgeous cherry cabinet to use with my KEF's.
Old 15th May 2014, 11:41 AM   #69
giro1991's Avatar
Just an update if anyone is interested .
I can't thank enough, diyaudio and those who helped me along on this thread to make this, so thanks again.
I aimed to make the enclosure without using screws for 'neatness', and I managed this until fitting the last side. I had no choice but to use atleast 3 screws on one corner. I fitted a cross-brace in the middle for stiffness, fitted using lots of strong glue, as the last stage.
Click the image to open in full size.Click the image to open in full size.Click the image to open in full size.Click the image to open in full size.Click the image to open in full size.Click the image to open in full size.Click the image to open in full size.Click the image to open in full size.Click the image to open in full size.
Monster awaits power up ...
I'm in the process of building the a hpf. I will be including it alongside a set of active Linkwitzriley 3-way crossover PCBs (available on ebay as a diy/premade ebayID: 111282526291).
I'll build all 3 boards into a Tupperware butterdish/box for simplicity, using a 230 to 24v transformer. I'm unsure how to go about binding the transformer legs. The mains side, theres 4 legs labelled 0-115 0-115, i'm told I should bind the 0 & 115 in the middle for 230input . Likewise the same for output but I'm stuck If I should power the HPF op amp and LR-XO using 24v all in series, have them seperate (ie 12v to, 12v to XO).
Any thoughts?
I will be applying hpf on vero board. I'm sure these values are right, I stuck to what elliotsoundproductions and what he said on his site regarding cap sizes and worked out the rest using this calculator. Can someone confirm this is okay?
Old 15th May 2014, 01:55 PM   #70
giro1991's Avatar
Also, regarding room modes.
I noted on a thread on gearslutz applying a 12db/oct slope from lowest mode (in my case 40hz) is reccommended.
Below, I actually got the OPA2134 for free as a sample after signing up to TI.com, pretty nifty.
Heres the "butter dish" project...
Sub recommendation.Hide this!Advertise here!
Recommendation needed cyto Class D 6 30th December 2012 08:53 PM
Sub Recommendation bdubbx Car Audio 30 13th April 2012 08:28 PM
Transformer recommendation mossen Power Supplies 6 17th October 2011 12:19 PM
Recommendation needed.. Dxvideo Chip Amps 10 13th December 2006 01:02 PM
Need recommendation for sub at work TechnoMage Subwoofers 12 19th September 2006 05:07 PM
