2.1 channel amplifier - diyAudio
Old 22nd December 2013, 07:35 AM   #1
Exclamation 2.1 channel amplifier
Dear all,
I am from one of the begginers in electeonics hobbysists. I have some knowledge about electronics. I decided to build 2.1 channel amplifier with TDA7377 + LM4558D using schematic given on following site -
Circuit power audio amplifier with TDA7377 2.1 – Stereo + Subwoofer 2x 12 Watts + 37 Watts | Xtronic Free Electronic Circuits and Informations
Now, I have two 10w 4ohm satellite speakers and 50w 4ohm subwoofer. But after assembling circuit sound is anyway not coming. I am using 12v power supply. And usb mp3 player as sound i/p. But there is noise only. Please help me with this circuit. Whether LM4558D requires negative (-12v) power supply??
Please help.....!!!
Old 22nd December 2013, 12:44 PM   #2
bjorno is offline bjorno  Sweden
Send a message via MSN to bjorno
Originally Posted by Vaibhav Shinde View Post
....Whether LM4558D requires negative (-12v) power supply??....!
The PCB doesn't allow a dual Supply so whats wrong with the shematic is the lack of bias needed to ensure proper Single Supply operation.
b
Old 23rd December 2013, 11:08 AM   #3
Dear Sir,
Thank you so much for helping me. I will make mentioned changes in the circuit & surely let you know the result. Please let me know, what power of speaker should be taken ?? Same as amplifier per channel output , less or more?? I have matched ohm rating... Please suggest for amplifier power & speaker power...!!
Old 23rd December 2013, 01:27 PM   #4
Dear Sir,
I think your choice of Speakers are quite good compared to the Amplifiers.
A small Headroom of a Power +dBW margin counted from the L+R Amplifiers to the Speakers (Your minimum Headroom:10log(12/10)=~0.8 dBW) is OK for low level listening.
Normally I guess, 6-7 W feed into the Speakers should sound good(~3dBW margin).
Concerning the Sub 50 W rating I think it's more important to look at the Driver x-max that normally limit max input possible Power to a much lower value than what the Driver is rated to. 18.5W feed into the Sub givea a~3dBW margin...
What Drivers(Brand names) are you using in what type of cabinets ,in what internal Box Volumes?
b
Old 30th December 2013, 08:43 AM   #5
Dear Sir,
You have mentioned about lack of bias in the circuit. But please note , IC1A & IC1B is single 8 pin IC (LM4558) . Similar case is for IC3A & IC3B. But in your provision you have only written IC1A , IC1B & IC3A . Sir, please let me know, whether same is appliable for IC3B also??/ Also please suggest, to which pin of IC1B the biasing circuit is to be connected??
Old 16th April 2015, 03:37 PM   #6
Bro I have problem in my tda7377 my circuits is based on PDF it running but!!! The problem is when I cranks the volume and give the bass of my circuit the system shutdown and I will re start again i n 12v pls help me
Need amplifier cabinet for 5.1 Channel Amplifier nalinb80 Swap Meet 0 23rd October 2012 06:52 PM
P channel amplifier Tekko Solid State 3 7th April 2012 12:10 PM
8 Channel Amplifier shzmm Chip Amps 1 4th June 2009 08:16 PM
Yet another N-Channel Amplifier Pelle Solid State 50 10th January 2005 07:48 AM
6-channel Amplifier halvardf Solid State 7 3rd July 2002 02:15 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
