Soundbar w/ external sub - no sub volume control
Old 22nd December 2013, 02:56 AM   #1
Beau1k is offline Beau1k  United States
Question Soundbar w/ external sub - no sub volume control
So I got this Audiosource S3D60 soundbar as a B stock manufacturer refurb for under $40 an Amazon...total score...I'm pretty happy considering I have been listening to TV speakers for the past year!!
I have my sub connected to one channel of the pre-out. When I change the volume from the soundbar remote there is no change to the subwoofer volume. So when I turn it down all the way I hear rumbles from the sub and when I crank it up the sub isn't loud enough! WTF over?!
I've always used receivers with SUB OUT options so is this a case of the soundbar just not adjusting the gain on the line level outputs? Or is it something where I need to use the line out in stereo? I'm like
Old 24th December 2013, 05:45 AM   #2
availlyrics is offline availlyrics  India
availlyrics's Avatar
Can you post pics. of how you made connections. Was the sub part of the soundbar deal?
Thanks,
availlyrics
Old 24th December 2013, 02:35 PM   #3
I have both optical audio and analog stereo audio for the input...you can switch between inputs so I tried both. Same result. And I'm taking one channel (1 red or 1 white) out to the sub. No the sub isn't part of the system.
Old 25th December 2013, 03:31 AM   #4
dheming is offline dheming  United States
dheming's Avatar
According to the user's manual the line output will track the volume of your source. So it's not really a pre-out that is controlled by the soundbar, but rather just a line level loop thru output.
Old 25th December 2013, 04:14 AM   #5
Where do you see that in the manual? And what manual are you looking at? Thanks everybody for the help/input so far!!
Old 25th December 2013, 06:23 AM   #6
dheming's Avatar
S3D60 owner's manual: http://www.smarthome.com/manuals/83105.pdf
On page two under Line Output it says: "This output can be connected to an external subwoofer using standard RCA cables to add even more bass output to your listening experience. The output of this jack will track the volume of your source."
Old 25th December 2013, 11:11 AM   #7
R.I.P.
Sounds like you need to match the bar and sub volume levels,
and then adjust volume from the source, not the soundbar.
rgds, sreten.
Old 25th December 2013, 03:12 PM   #8
Can you do that with the DirecTV genie?
Soundbar w/ external sub - no sub volume controlHide this!Advertise here!
Volume control on DVD player remote. Lose resolution at low volume? Circlotron Digital Source 2 10th June 2011 07:20 PM
Replacing broken volume control with digital volume control Gunawan W Solid State 19 15th December 2010 10:46 AM
External Control for Virtual DJ ZuMbAiU Digital Source 0 11th July 2006 04:46 PM
remote control motorised control for volume pot/knob CharlesY Parts 0 25th July 2005 11:12 AM
External Volume Control asgorath Chip Amps 1 23rd July 2005 09:38 PM
