Portable speakers, 5.25 subwoofer, passive radiator; cylindrical - diyAudio
Old 25th November 2013, 10:16 PM   #1
tigox is offline tigox  Portugal
Post Portable speakers, 5.25 subwoofer, passive radiator; cylindrical
Hello there fellas, i've been working on portable 2.1 speaker cylindrical shaped, so basically i am going to use a 5.25 kevlar subwoofer (902.420) and i was thinking of using a 5.25 passive radiator, the question is, on WinISD, 38Hhz are located ate -7db, the subwoofer is rated at 100W and my amplifier would feed it around 60 RMS, so, is -7db too low? should i go with a port instead of goig with the PR?
Below is images of the speakers, and WinISD tests (vented- white line; purple-PR and yellow-sealed). On the sketchup, the PR is on top and the sub on the bottom.
Any help would be appreciated
Old 27th November 2013, 06:16 AM   #2
Inductor's Avatar
(It's good to measure Skytronic drivers)
In a standard application (original spec) a BR 5-7L doesn't look that bad tuned to 45Hz. Port 5cm, 37/38cm long. (F-6 dB 40 Hz)
Old 27th November 2013, 08:27 AM   #3
Thank you so much for your reply, but about the port, is it too bad what I have with the radiator? Because it's basically part of the design having the PR
Thank you
Old 27th November 2013, 01:11 PM   #4
Inductor's Avatar
I don't know your speaker specs. Enclosure volume, tunning and PR specs.
If you do the calibration-simul. from port to PR it should be fine.
Old 27th November 2013, 01:29 PM   #5
What exactly do you mean by saying port to pr simulation?
Old 27th November 2013, 02:24 PM   #6
Go to the SPL tab, not the Transfer Function.
There you can compare the boxes much better. Post pics.
Old 27th November 2013, 06:44 PM   #7
Thank you for the tip, i did not know this function
Anyway, here are the pics of the vented at it's fs and also the PR:
Click the image to open in full size. PR
Click the image to open in full size. VENTED
so they're both at about 75-80db, is that good or bad?
Old 27th November 2013, 11:22 PM   #8
bitSmasher's Avatar
"portable"... is this for outdoor use?
Old 27th November 2013, 11:27 PM   #9
sort of, yeah, it's the kind of speakers to have at the pool side i guess haha
why, do you have doubts of it being portable?
Old 28th November 2013, 02:04 AM   #10
bitSmasher's Avatar
I do question the amplifier power you're quoting, and also wonder if it's worth pursuing bass reproduction on a small scale outdoors
My first subwoofer. Peerless xls10 in passive radiator application 131183914 Subwoofers 9 9th July 2014 10:18 AM
12" Cube Passive Radiator Subwoofer russforrest Subwoofers 6 5th August 2013 02:35 PM
Peerless Subwoofer with Passive Radiator GlennME Subwoofers 3 15th February 2007 09:34 AM
Subwoofer and Passive Radiator question... WolfmanX Subwoofers 0 19th November 2002 01:10 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
