Will this config work?
Line out from laptop -> L+R line in on subwoofer plate amp -> L+R line out -> plate amp 2 -> plate amp 3 -> stereo amplifier -> speakers.
Will this result in a low pass signal, from plate amp 3 to go through to the stereo amp? Or will it be a full bandwidth line level signal?
This is particular model. http://www.parts-express.com/yung-s...ofer-plate-amplifier-module-no-boost--301-500
It doesn't say whether the line out is filtered or not.
You're talking about the laptop line-out I suppose? It's definitely a headphone out. Probably a dual headphone/line out. Has a little headphone symbol. So, from what I understand, headphone outs have lower output impedance. In my case, will it be happy driving these many amplifiers? I don't have an engineering background.
I'll look both up. I have another idea. Laptop headphone/line out -> Stereo amp with line out. hi-level ->speakers. line out-> plate amps 1,2&3. Is this pretty much the same as above except that this signal wont be low pass filtered?
I am asking since, I'm considering a small tripath amp with no line out. And I'd also like to avoid a preamp or external dac. Due to budget constraints. Atleast for now.
