Tore my spider? - diyAudio
Old 26th October 2013, 09:43 PM   #1
Default Tore my spider?
How do i fix my spider it detached from the cone
Old 26th October 2013, 10:27 PM   #2
Speakerholic
Cal Weldon's Avatar
Is the spider a pleated fabric and the cone paper? If so I would try white glue, an artist's paint brush, a steady hand and possibly multiple applications.
planet10 needs your help:
Let's help Ruth and Dave
Old 26th October 2013, 10:57 PM   #3
If the original glue is still holding part of the spider that ripped away from the rest, the spider is burned out and a little or a lot of glue wont fix much anyway. Pic.?
Old 27th October 2013, 01:04 AM   #4
Hi ,
Please go ahead with Cals suggestion on papers cones , treated cones etc. for PP cones you will need to use Loctite Prism Gel (or their latest version of PP to fabric glue - commonly available with all Loctite dealers)
Suranjan
Old 28th October 2013, 12:48 PM   #5
SIDEWINDER 18X's Avatar
If the spider is detached from the neck joint, white glue will not work. Use a 2 part slow cure epoxy . Apply a thick bead at the detached area and turn the driver upside down & allow it to cure. This also depends on how much spider neck area is detached from the cone & coil joint. If the detachment is over 40-50%, you need to pluck off the dust cap and center the coil with shims and then apply the epoxy to avoid misalignment. If you want to do it fast you can use rubber toughened adhesives ..... Loctite 480.
If you are not an expert in doing the above it is strongly advised to get it fixed by any professional reconer in your area.
Old 28th October 2013, 01:16 PM   #6
lanchile's Avatar
if you glue back the spider wrong...you will hear it!
The voice coil will hit the sides. Try to see the old mark, how low or high was the spider attached to the voice coil before it got loose. This is like fixing the surround of speakers....if you put them "crooked" they will sound "horrible". I have seen and heard them:eek
The point here is to "PRECISELY CENTERED IT"
oooh and use a STRONG glue!!! the spider will get a lot of in and out movements pushing the cones.
Make it simple...Make it better!
Any way to fix a saggy spider? chipper Car Audio 3 23rd August 2013 09:38 PM
New dual spider woofer GordonNHT Everything Else 5 13th June 2007 03:11 PM
Spider surgery - anyone? Jorge Multi-Way 6 11th November 2005 09:11 PM
OK, tore apart a BackUps Pro 650 JCoffey Chip Amps 4 29th August 2003 01:04 PM
Copyright 1999-2017 diyAudio
