if using 1" thick MDF,,is internal bracing still needed? - diyAudio
Old 13th October 2013, 01:43 PM   #1
Default if using 1" thick MDF,,is internal bracing still needed?
It would be for a 2 cubic foot sealed enclosure. With walls that thick it would be pretty stout,,just wondering if the bracing would be overkill. It would be for a 12" Dayton Ultimax,,
Old 13th October 2013, 02:26 PM   #2
danny_66's Avatar
Definitely, bracing is more effective than thicker walls.
Here's a research.
My RefSpeaker
Old 13th October 2013, 02:34 PM   #3
Alrighty then. thanks for the link. Can't argue with data and graphs. I'll stick with 3/4" MDF braced very well.
Old 15th October 2013, 10:01 AM   #4
ODougbo is offline ODougbo  United States
I was a fan of 1" mdf for a long time, now those boxes are stacked in a pile and in the process re-building all of them. I like the idea of laminating mdf/plywood, 1/2" on 1/2" e.g.
Old 25th October 2013, 10:04 AM   #5
Juhazi is offline Juhazi  Finland
Juhazi's Avatar
When we consider just subwoofers, box wall "ringing" at several hundreds of Hz or kHz range is not an issue (looking at danny_66's link). The problem is ballooning with sound pressure which causes all kinds of vibrations and distortion peaks.
Traditional and proven way to make a good bass cab is to use bracing, it is effective against ballooning. Wool or lining are not needed, with the exception of filling sealed cabs to get a little higher Q.
Lamination is the best way to make a good full range speaker's cab, and add bracing there too! Inside should be lined or filled too.
AINOgradient speaker project
Old 25th October 2013, 01:32 PM   #6
colofan is offline colofan  United States
Well missing from the study at least the translated version is what is the input signal going into the box? If you use a ported design the over and under pressure is not what is being modeled here (sealed box).
If the experiment was to use a pink noise generation with a narrow bandpass of what actually frequency would being developed in a sub-woofer I would concur that the data points to better bracing however it does not.
Also of note in secondary output could be measured with a contact sensor on each panel to see how much engery is be loss through the side and back walls of a box.
Old 25th October 2013, 06:57 PM   #7
myhrrhleine's Avatar
Hello, the thickness determines how far the span can go.
The mathematics is complex, but basically when you double the thickness you can double the width without adding bracing.
So 6" with a 1/2" panel thickness is equal to 12" and 1" thickness.
[Grasshopper]:Old man, how is it that you hear these things?
[master]:Young man, how is it that you do not?
Old 25th October 2013, 07:19 PM   #8
frugal-phile(tm)
planet10's Avatar
You would be further ahead with 18mm (3/4") quality ply, or even 15mm.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 25th October 2013, 07:19 PM   #9
brig001 is offline brig001  United Kingdom
True. Counter intuitively you will need a more rigid box if it is ported.
Ported Enclosure Pros and Cons | KICKER
Brian
Subwoofer enclosure internal bracing rocko1290 Subwoofers 20 22nd February 2017 03:19 AM
Plastic speaker cabinets - improving internal bracing & damping turbodawg Multi-Way 29 17th November 2014 08:34 PM
Internal bracing vs SPL firepinch Subwoofers 17 28th November 2006 01:54 PM
Port lenght - Thick MDF Cabinet richardtextex Multi-Way 6 26th October 2006 05:27 PM
bracing of large cabinets and effects on internal reflections JRKO Multi-Way 7 12th April 2005 07:12 PM
Copyright ©1999-2017 diyAudio
