Bass reflex woofer selection and modeling - diyAudio
Old 11th October 2013, 03:08 AM   #1
Default Bass reflex woofer selection and modeling
Hi folks, first time posting. I have long studied the serious bass research that goes on here. I got started wanting to build some BFM T60s, of course, years ago and have also become enamored with the eloquent TH designs that have evolved over here - and yet, I still have not done...anything.
Recently at an outdoor event on a beach I was dismayed by the sound. Long story short, I'd like to build some decent subs that have BIG wheels on them to be lugged on a sandy downhill path 1 mile to the beach. I know that I want BR boxes because I have hand tool only woodworking skills (and patience!)
8 cubic ft (240l) boxes are fine and I'd like to hit 40Hz.
My question is in regards to modeling BR boxes. I have been using WinISD .50a7 and have found that my designs always reach xmax well before approaching the thermal limits. In the graphs below you will see a graph of each box SPL @ 1 meter given the maximum amount of power to hit xmax (each noted in the key). Are BR boxes known to experience over excursion above the port tuning frequency - as you will see from the 2nd graph, showing cone excursion, it is the 50-60Hz range that is causing problems. Then again, maybe all of my modeling is wrong! The cheapo MCM drivers did not list BL - I entered it as "10" but have thought about calculating it and/or moving on to HornResp.
Thanks,
J.P.
PS: 110dB/1m sounds fine to me...it's only for about 20-50 people.
Old 11th October 2013, 03:38 AM   #2
Lusk is offline Lusk  Australia
Lusk's Avatar
Is there any reason you have the port tuning for example with MCM at 41 Hz? Is this for more output?
why not lower at around 32Hz like WinISD should suggest.
Old 11th October 2013, 04:01 AM   #3
Yes, it is for higher output around 50Hz. A lower port tuning does not significantly raise the response at 40Hz so I figured I'd rather just take the extra SPLs.
Old 11th October 2013, 07:36 AM   #4
GM is online now GM  United States
GM's Avatar
A pair of these in 8 ft^3 puts out far more SPL: Dayton Audio PA460-8 18" Pro Woofer 295-036
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 11th October 2013, 08:15 AM   #5
I just modeled a single PA460-8 in the 8cuft box tuned to 40Hz and it does not reach xmax until 300W (it's 500W RMS) which is much better. This means that it can reach a solid 120dB 1m at 40Hz and peaks at 122dB at 50Hz. Thanks, that's just the sorta lead I needed.
Modeling the suggested sizes, 4cuft and 53Hz, shows that it does not reach xmax until 500W but lacks extension.
Old 11th October 2013, 08:49 AM   #6
GM's Avatar
Considering their relatively low cost, then why not [2] in 8 ft^3/~40 Hz?
GM
8" woofer selection for high performance 3-way with bass boost pawelp Multi-Way 23 4th August 2013 05:07 PM
Decent 18 inch woofer for a 7.5~8 cubic foot bass reflex enclosure? Upstate NY low life Subwoofers 9 9th July 2011 09:35 PM
bass reflex woofer in acoustic suspension mosfetmaster Multi-Way 11 6th October 2010 11:55 PM
HELP! Bass-reflex design for vintage University woofer C-15HC davidbosch Subwoofers 9 12th December 2007 03:26 PM
Bass Reflex Guss Multi-Way 1 15th December 2003 03:33 AM
Copyright 1999-2017 diyAudio
