Help with formula - Maximizing Performance from Loudspeaker Ports?
Old 16th September 2013, 10:19 AM   #1
eqjive is offline eqjive  United States
Default Help with formula - Maximizing Performance from Loudspeaker Ports?
Can anyone clarify this formula from the AES paper 'Maximizing Performance from Loudspeaker Ports'? (see attached screen shot). I'm looking to create a spreadsheet (as the paper suggests possible) to determine tuning frequency of heavily flared ports (NFR .5 - 1).
It is formula number 11, page 14 of the paper 'Maximizing Performance from Loudspeaker Ports' or page 32 of the J. Audio Eng. Soc., Vol. 50, No.1/2, 2002 January/February
I'm having some trouble figuring this one out... what are the units to be used if speed of sound is given in meters, what should throught area, diameter, volume etc be?
Can anyone give an example using the formula so I can understand where I am getting confused?
Thank you!!
EqJive
File Type: png Screen Shot 2013-09-16 at 5.04.19 AM.png (104.6 KB, 108 views)
Old 16th September 2013, 10:48 AM   #2
R.I.P.
I'd uses cm, cm/s, cm squared and cm cubed for calculations.
Convert C to cm/s and Litres to cm cubed.
Really doesn't matter as long as your consistent.
What you uses to input parameters can be converted
in the calculations, so use whatever input format
you like like C in m/s and Vb in litres.
Note that big ports will reduce the actual Vb.
rgds, sreten.
If its going to end up part of something more complex
standardise on m, m/s, m squared and m cubed for
all calculations and convert the input / output format.
Old 16th September 2013, 10:49 AM   #3
I get the impression that everything is in metres.
regards Andrew T.
Old 17th September 2013, 02:11 AM   #4
OscarS is offline OscarS  United States
As reten said, so long as you're consistent you can use different units.
The main idea is to realize that since c is in units of "distance/time", and frequency is "1/time", you need to cancel out the "distance" unit in the numerator that "c" contributes. That means that the outcome of the square root function has to simplify down to "1/distance". Sure enough, Aeff= distance˛, and the product of Leff*Vb = distance^4. Distance˛/distance^4 reduces to 1/distance˛, the square root of which leads to "1/distance".
So as long as the units for distance are consistent, the formula will churn out the correct numbers.
Old 17th September 2013, 01:50 PM   #5
Thank you!!! With your help, I figured it out.
- EqJive
Help with formula - Maximizing Performance from Loudspeaker Ports?Hide this!Advertise here!
Active high dynamics/SPL & high performance loudspeaker system for my living room…! Robert GS Multi-Way 84 19th January 2017 10:34 AM
Maximizing YouTube download audio quality oltos PC Based 8 26th November 2012 09:41 PM
Class T - maximizing damping factor, any ideas? Disney_SK Class D 51 22nd June 2008 01:56 PM
Loudspeaker formula freedom Multi-Way 17 18th November 2004 09:49 PM
Loudspeaker Filter Formula's Lars Clausen Multi-Way 11 19th November 2003 05:22 AM
