Vintage NEAR Boom-4 Subwoofer - diyAudio
Old 2nd September 2013, 03:11 PM   #1
Gwho is offline Gwho  United States
Default Vintage NEAR Boom-4 Subwoofer
Any help would be appreciated. I recently picked up a subwoofer from the 1990s that I would like to restore and improve if possible. I cannot seem to find any information on the subwoofer. The subwoofer was built by NEAR (New England Audio Resource). It is a passive subwoofer requiring amplification. It is a ported design that has 4 8" woofers. It appears that each side (2 8") are independent from each other as they are side firing with each side having a separate port. Does anybody know anything about this device (frequency response, efficiency, power requirements etc.). Is it only good for HT or could it be used for a two channel system?
Thanks for any input you may have.
Best Regards,
gwho
Old 2nd September 2013, 05:57 PM   #2
chris661's Avatar
If there's two sets of inputs, that suggests to me it was intended to be run in parallel with main speakers, in a 2-ch set-up.
An impedance sweep would be rather useful:
the dip between two impedance peaks is the port tuning. Above and at port tuning, power handling is very large. I'd expect 4x8"s to go rather loud, so long as you don't go below port tuning.
Photos would help, too
Chris
Old 2nd September 2013, 07:15 PM   #3
I will try to get some pictures up if I can figure it out.. The speaker measures 3' x 2' and is about 20" high. I do not know much about speaker building (I'm better at electronics). Is an impedance sweep a measurement of the speaker output over frequency?
Gary
Old 2nd September 2013, 07:25 PM   #4
weltersys's Avatar
Gary,
An impedance sweep is a measurement of the speaker impedance, measured in ohms, over frequency.
Speaker output level is measured in decibels, (dB) dB SPL (Sound Pressure Level) using a dB meter or more advanced RTA or FFT devices.
You can determine the Fb (tuning frequency of the box) visually using swept sine waves (available for free on the web), the speaker movement (as well as impedance) will be at minimum at Fb.
Below Fb, ported boxes tend to drop in level at around 24 dB per octave.
Old 3rd September 2013, 02:56 PM   #5
I got a couple articles on doing an impedance sweep. I will read them and attempt a measurement.
Gary
Old 4th September 2013, 04:53 PM   #6
Here are some pictures of the subwoofer. It has two drivers on each side.
Old 4th September 2013, 04:55 PM   #7
I was told that the woofer cone is metal.
Old 5th September 2013, 05:57 PM   #8
BP1Fanatic's Avatar
Since you didn't provide the model number, try here.
Bogen Document Index
Old 6th September 2013, 09:31 AM   #9
djk is offline djk
djk's Avatar
Boom 4-FG
Manufacturer: NEAR-New England Audio Resource
Candidates for the Darwin Award should not read this author.
Old 6th September 2013, 12:37 PM   #10
BP1Fanatic's Avatar
About Bogen, Location, Other web sites, Board of Directors
Dx Boom, the small brother of a complete line of subwoofer power amplifiers destroyer X Solid State 40 18th October 2013 09:25 PM
Vintage Console Subwoofer Conversion cogitech Subwoofers 6 11th April 2013 11:35 PM
Vintage VMPS Larger Subwoofer repair audiomagnate Subwoofers 3 16th December 2012 09:59 AM
Protecting vintage subwoofer cones......need advice from the experts! sangellga Subwoofers 5 21st January 2011 09:30 PM
Vintage AR subwoofer - woofer replacements? midside Subwoofers 0 8th May 2009 03:05 AM
Copyright 1999-2017 diyAudio
