12" symmetrical tapped horn plan? - Page 2 - diyAudio
Old 2nd September 2013, 07:45 PM   #11
It sounds mean but I have people to lift carry and stack and I don't mind paying for the wood if it makes it pretty! Also I can build one for mums living room
Old 2nd September 2013, 08:08 PM   #12
weltersys's Avatar
That's nice.
Have fun building!
Old 2nd September 2013, 08:32 PM   #13
I still however have no idea how to go about designing one, can anyone help?
Old 3rd September 2013, 08:53 AM   #14
djk is offline djk
djk's Avatar
"I would not dismiss TH for the "kick" range."
So what kind of slopes, crossover points, delay settings, and phasing are you using?
Candidates for the Darwin Award should not read this author.
Old 3rd September 2013, 12:49 PM   #15
Ermm lr24 with the kicks running 60-125, I still gotta do the delay properly but by year it sounds nice 4ms behind the tops, as for phasing, i fully Dont understand it enough but im willing to learn if someone wants to make it easier for me to understand?
Old 3rd September 2013, 05:54 PM   #16
weltersys's Avatar
LR or BW 24 dB per octave in general, the delay times, crossover points and in band and out of band parametric EQ all vary with the type of top cabinets and sub cabinets used.
The alignment of a sealed front loaded top would be different than a horn loaded or ported top, all would require different settings to make a smooth phase transition.
Fortunately, DSP can save dozens of settings .
When I had a pile of FLH, BR, and TH subs for sale, I aligned each to the same top cabinet and would switch DSP settings for each.
If I forgot to switch settings when switching subs the results were not good..
One 15" Tapped Horn vs Four 8" Tapped Horns Patrick Bateman Subwoofers 28 12th February 2013 10:12 AM
FS: Lab 12-tapped horn enclosure layertone Swap Meet 0 17th November 2012 05:27 PM
12" tapped Horn Plans? djlivex Subwoofers 14 22nd March 2012 01:17 AM
mcm 8" dual tapped horn plan soundhead Subwoofers 13 27th May 2010 03:28 PM
Lab 12 Tapped Horn, Ron's Austin II, T-Horn, CNC Photo Background layertone Subwoofers 15 23rd January 2010 05:12 AM
Copyright 1999-2017 diyAudio
