Got 18" for free, looking for enclosure ideas for HT? - Page 2 - diyAudio
Old 2nd September 2013, 03:16 AM   #11
BHTX is offline BHTX  United States
BHTX's Avatar
As already pointed out.. with a Qes that high, I'd put it in a large sealed enclosure, and EQ it a bit, using the most powerful amplifier you have on hand. I haven't done any sims yet, but a suitable ported enclosure would likely be ridiculously large.
Edit: WinISD Pro says 10.1 cubic ft for 0.707 Qtc, 28-29 Hz F3. And that's if the T-S parameters are accurate. Qts is often higher than spec'd. So, build the largest sealed enclosure you can tolerate, stuff it with several pounds of polyfill (or whatever), and be done with it. You can apply a tiny bit of boost on the low-end, but only a little, and only if the EQ can target 20 Hz or less. A digital low shelf will work best. And you will need quite a bit of power.
Edit again: 20 cubic feet tuned to 15 Hz would also work..
Old 2nd September 2013, 03:23 AM   #12
How ridiculous? Curious minds want to know
Is there a good website where I could model this sub in a sealed enclosure to see how it does at around 17hz?? Is that too low to expect much output from a sealed enclosure?
-Jamie M.
Old 2nd September 2013, 05:51 AM   #13
ßart West-VL.'s Avatar
Originally Posted by sine143 View Post
Comparitvly, its "not expensive". however, anything that costs 360 is expensive in my book. more than half a months rent.
One big difference, the driver costs are once, your rent is to be paid again and again, every month...So that's not a comparison.
Break in your loudspeakers at 35% RMS power Right-click'save as...'
Brown noise mono 192kbps(hit "repeat")
Old 2nd September 2013, 05:55 AM   #14
sine143 is offline sine143  United States
It is a comparison when i buy a speaker driver, cant pay rent that month and get evicted lol
Old 2nd September 2013, 11:06 AM   #15
Ile is offline Ile  Finland
Get one or three more and make IB.
Old 2nd September 2013, 01:06 PM   #16
Inductor's Avatar
-Jamie M.
Jamie, yes.
Subwoofer Box Enclosure Design Calculator - Sealed Ported Bandpass Closed Vented
LinearTeam
Old 2nd September 2013, 02:14 PM   #17
Scott L is offline Scott L  United States
Default 2 ohm coils
One issue no one has brought up yet, is how to handle those 2 each@
2 ohm voice coils (?)
One option is to series them for a more stable 4 ohm load, but the series thing is often frowned upon.
Old 2nd September 2013, 07:01 PM   #18
Sweet, thanks. I'll get plugin numbers in.
I was going to run the voice coils in series, 4 ohm bridged on say EP2000 or similar. What are the issues running voice coils in series?
-Jamie M.
Old 2nd September 2013, 07:21 PM   #19
Wow?
That +4db at 17hz has me excited, but is that 42.5 cubic feet correct?!
-Jamie M.
Old 2nd September 2013, 07:35 PM   #20
weltersys's Avatar
Jamie,
Sounds like it could be correct, and it probably will hit the excursion limits with a lot less than full power in that large of a box.
I'd try a tapped horn like the Gjallerhorn if considering a 4 x 4 x 3 foot box.
That would give a lot more "wow".
Series voice coils are not a problem as long as the polarity is correct.
New HT subwoofer. Dayton Ref 18" m R g S r Subwoofers 84 20th July 2013 12:24 PM
18" in horn for HT ßart West-VL. Subwoofers 40 17th July 2013 03:23 PM
18" Sub Enclosure omnipotentgeass Parts 1 21st November 2011 09:35 PM
Single 18" Bass Bin - Plans & Ideas nawtychesco Construction Tips 2 16th March 2010 11:08 AM
Copyright ©1999-2017 diyAudio
