Hello,
I'd like to build a T-Line subwoofer enclosure for a Tang Band W8. Since I'm new to building T-Lines, I'd like to get people's opinions on this mock up.
Is the line length correct for the desired tuning?
Does the 15 3/8" x 5" box near the driver affect the t-line?
Do I need to consider anything else?
Wood width: 3/4"
Box Height: 24"
Box Width: 21"
Box Length: 19"
Port dimensions: 2.25" x 22.5"
Port area: 50 inches squared
Line length: 101"
Driver: Tang Band W8-740P 8" Subwoofer 264-854
Amplifier: Dayton Audio SPA250 250 Watt Subwoofer Amplifier 300-803
Desired tuning: 30Hz - 35Hz
Thank you
Wood width: 3/4"
Box Height: 24"
Box Width: 21"
Box Length: 19"
Line length: 101"
Thank you
Horn Response will tell you the answer right away. Using it?
I've never heard of it but I'll try it now
Thanks!
I've made a new design that's more space efficient.
