Sub for home system - diyAudio
Old 13th August 2013, 10:04 PM   #1
Rephlex is offline Rephlex  United Kingdom
Default Sub for home system
Hi, I'm in the process of converting my home system from a fairly standard set of bookshelf speakers (that I like the sound of) to a tri-amped setup and I need a sub for that to work..
The ported bookshelf speakers I've got peak at 105Hz with a resonant peak from the port at 40Hz. I'm thinking of filling in the port and setting the crossover at around 100Hz (I'll test them again and see how this affects the response).
I'd like to use 2 x 12" or 10" drivers mounted on opposite faces of the enclosure (after being inspired by Laurence Dickies work). I'd rather not have to EQ the subs so I thought about having a ported enclosure tuned to 30Hz or so. A volume of 50-100l would be OK as I'd like to be able to move the subs if I need to.
Or are there any horns with that sort of volume that could do what I want?
Amp wise I'd like to use a 2x 150W RMS Tripath based amp that I built but I have also got a 4x 600W RMS amp (1200W bridged) amp knocking around - ideally I'd save that for powering the mid of my PA and get some more efficient drivers for the subs..
Thanks!
Old 14th August 2013, 06:05 AM   #2
Inductor's Avatar
A volume of 50-100 L with 2 drivers gives a net vol between 25 to 50 L/max. each driver.
Scanspeak 26W 4558T00 Discovery
Alcone AC 10 HE
SW-12-04 - GR Research
Mivoc AW3000
Atohm D300 P04
Volt RV3143
Old 14th August 2013, 06:31 PM   #3
EQ may be more useful for in room response rather than just to tailor the response of the subwoofer itself.
Minidsp is only 125 or so, I have a few and love them.
Old 14th August 2013, 11:55 PM   #4
dangus is offline dangus  Canada
I would go with a sealed sub, since that gives better transient response, and a slower roll-off which matches the natural room gain at low frequencies. Sealed is much more forgiving of errors in T-S parameters, or parameters which vary with environmental conditions.
Old 15th August 2013, 03:20 PM   #5
I was thinking of using a ported system because I listen to music with a lot of bass and I was keen to be able to get the subs to produce below 30Hz without using too much power.
I need the speakers to be 4 ohms to get the most from my amps. What drivers would you recommend for a sealed enclosure?
I've got an Ultradrive from my PA so I can build the speaker and then play with the EQs to see what I'll need for the permanent installation. I'm using two of Rod Elliott's 24dB Linkwitz-Riley crossovers so I can always add an additional op-amp based EQ to the subs if I have to.
ICE system to be used as a home system new2iceDIY Car Audio 9 19th May 2013 05:13 PM
Home Theatre System vintageaudioman Swap Meet 2 2nd September 2012 08:24 PM
home made system Harry Fisher Multi-Way 6 1st August 2009 10:18 PM
Home theater system Supertib Solid State 9 8th December 2005 07:28 PM
Copyright 1999-2017 diyAudio
