Reflex Enclosure question
Old 7th August 2013, 08:39 AM   #1
georgewood is offline georgewood  Thailand
Default Reflex Enclosure question
I've been given a few 2.1 computer speaker setups and am looking to simply replace the drivers and amplifiers with better components.
Most of the mains have either 2.5" or 3" fullrange speakers which are simple to upgrade and some of the subs have 'adequate' woofers which I may retain.
Upon stripping the devices down, I am somewhat confused, as some of the enclosures made by SAAG are bandpass constructions however the drivers are mounted with the cones facing into the sealed enclosure and the backs facing the ported enclosure (which also houses the amplifier).
Is there any reason that this would be done?
Old 7th August 2013, 09:28 AM   #2
Default Image of enclosure
The drivers are mounted like this.
Old 7th August 2013, 01:07 PM   #3
Arty is offline Arty
vented magnet pole piece sometimes can make a nasty noise.
by making the backside of the driver face a closed cavity it is "sealed" away.
so it reduces this noise.
Old 7th August 2013, 02:57 PM   #4
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
Originally Posted by georgewood View Post
.... backs facing the ported enclosure (which also houses the amplifier).
or just a simple matter of convenience, making everything easier to mount and connect
Old 7th August 2013, 03:24 PM   #5
Cal Weldon is offline Cal Weldon  Canada
Speakerholic
Cal Weldon's Avatar
I believe it's the other way round.
planet10 needs your help:
Let's help Ruth and Dave
Old 7th August 2013, 04:12 PM   #6
I thought the explanation might be as simple as this ( avoid having to route and seal the driver connection wires back through to the ported enclosure ), but I was intrigued and as I didn't know, I thought I'd ask :-)
Maybe I'll just switch the driver around and seal the wire exit hole with silicon and see if that improves the overall sound.
Old 7th August 2013, 06:51 PM   #7
Speakerholic
Cal Weldon's Avatar
I have a feeling you won't hear a difference or if you do, it won't sounds as good. You have to think it's like that for some reason.
Old 7th August 2013, 07:23 PM   #8
weltersys is offline weltersys  United States
weltersys's Avatar
The amplifier and speaker magnet structure radiate heat.
The port allows that heat to dissipate through the exchange of air, lowering the temperature, good for electronic and speaker longevity.
Old 9th August 2013, 01:05 AM   #9
Inductor is offline Inductor  Portugal
Inductor's Avatar
Plus, both cavities I & II are tunned to a certain frequency. Changing that initial concept (by changing the position of the driver you are changing both the internal volume of the 2 cavities) can only make things worse, if they were well designed to start with. Also as weltersys mentioned already you screw the venting of the magnet/motor.
Reflex Enclosure questionHide this!Advertise here!
Double bass-reflex enclosure. simpleacoustic Subwoofers 10 23rd October 2011 02:44 PM
Base-Reflex enclosure. Larry Multi-Way 11 16th May 2006 05:53 PM
Converting a reflex enclosure to aperiodic Ian J Multi-Way 2 30th January 2004 06:47 AM
Bass reflex enclosure Opie Subwoofers 5 5th January 2002 01:36 AM
