Help. If you are running a long distance first you need a good balanced (read professional) or unbalanced connection.
Basic Subwoofer Setup Guide NOT for Dummies | Audioholics
We could do with more info on your setup.
If you have a digital multimeter set it to AC 10 Volts. Grab a 50Hz .WAV file from the internet a play it @ a lowish volume & compare the output from the Sub Receiver terminal/s & the Sub input/s. THey should be the same, if not you probably have a wiring/connector problem, or faulty Sub or Receiver.
Don't for get to try connecting the Sub box with a short lead to the Sub output & see how that is.
Many budget DMM's don't have a low voltage AC range, but they do have an Ohm-meter.
This will work on interconnects and speaker cables.
Get a resistor, any wattage of about 10 to 50 Ohms.
Disconnect the cable at both ends, measure on wire to the other, the resistance should be near infinite.
Measure the resistor value, connect the resistor across the 2 wires at one end.
Measure the resistance at the other end of the cable, the value should be just slightly more than the resistor by it's self.
